Aquawax, as the name implies, is meant to be used with water - but not much water. The name also implies it is a wax but in truth it is not a wax. The method someone suggested above of washing, blowing dry and then while the car is still somewhat wet, spray AW and dry with a microfiber. Your towel will glide much easier on the paint making drying a breeze. The bonus is that you will get a nice shine and a little added protection as well. One thing to remember is that the car should be totally clean when you use AW, either dry as a "topper" or as a drying aid.
If you want to use a QD for dust, finger prints, pollen, and minor dirt you are better off using Duragloss Fast Clean And Shine, a true QD with nice gloss as well. I have recently started to use a combination of FC&S and AW at a 3:1 ratio (3 parts FC&S and 1 part AW). This home brew QD works very well for me when the car is not quite 100% clean.
Here is another tip. If you can't find AW locally (eg, there are no stores in my part of Texas that even sell Duragloss products), you can always substitute Lucas Slick Mist Speed Wax. It acts the same way as AW, is just as versatile, just as cheap, smells great and can be found everywhere, even WalMart. In fact, I think as a drying aid it surpasses AW (although it is not quite as glossy). Lucas is a very good and easy to find product that is often overlooked.
