Preparing for LSP?
galaxy
Member
So when you guys get the itch to try a new product, but your surface is already perfect and covered with your favorite LSP, what do you use to clean or strip it down, with no paint correction needed, to play with the new LSP? If it matters, want to try out Wolfgang Fuzion.
Before totally stripping the entire
vehicle of the existing LSP...
I'd first:
-pick out 1/2 section of a
panel (hood/trunk lid); and,
-use a very light polish (to
remove the existing LSP from
its surface); and, then:
-apply the different LSP (Fusion)
to see if I like it better than the
other LSP.
•If yes:
-use the same polish to remove the
rest of the existing LSP.
-finish applying Fusion to the other
panels' surfaces.
•If no:
the Fusion from the 1/2 test panel
-reapply the LSP that was previously
on the test panel
Hey Bob, what's your opinion on paint cleansers to handle this task vs. a light polish? Something like McKee's Coating Prep Polish. Do you think it would be good in this situation?
Maybe even better considering it doesn't contain abrasives like a polish and therefore no unnecessary rubbing away clearcoat. What do you think?
I was wondering the same thing. If using a "paint cleanser" with a light polishing pad ( eg Lake Country green pad) would be sufficient to remove wax and/or sealant.
It depends on the paint cleanser. The micro abrasives ones clean up a lot better although pinnacle black label paint cleanser will do the job if you pair it with a pad with mild cut like green.
From my above posting in this thread:
I'd first:
its surface);
I've found out that the
guaranteed way to "strip"
all/any LSPs is via polishing.
Someone should do the community a favor and perform a few tests and post the results [with pics] to confirm the abilities of paint cleansers.
Guess I'll stick with what works then...205 on a white or black pad. Most likely a black pad if all I'm doing is cleaning up for a LSP. Maybe follow this with a 10% IPA wipe down...yea/no?
________________________________
"I Saw a Man Pursuing the Horizon"
{~Stephan Crane}
I saw a man pursuing the horizon;
'Round and 'round they sped.
I was disturbed by this;
I accosted the man.
'It is futile', I said,
'You can never---'
"You lie", he cried;
And ran on.
I rarely desire to change up LSP's in early to mid term of it's durability. With that said, i use either my car or the wife's to try a new LSP and both vehicles most times don't require much if any abrasives. For those times i use DG501 to "clean" the paint.
Theirs been a couple threads in such test..one was here on Autogeek
Gist of it was that most things that are deemed to remove it simply left a surfactant to mask LSP properties..
Just do a Polish and know it's gone.
The 1st thing that comes to mind is Pipuk's thread... I revisited that thread just a few days ago... I made it through about 3/4 of it before I checked out [it's a very long thread] But I didn't see any tests involving paint cleansers, specifically McKee's Coating Prep Polish. If I missed it, then my mistake... But I'd really like to find out if something like that product fills the need or not.
I don't know about the chemical paint cleaners. Mike talks a little about it in this thread, and working backwards.
http://www.autogeekonline.net/forum...ble-immiscible-wax-paint-sealant-bonding.html
If your paint were soft, you may be better off polishing than using a chemical cleaner, or even just topping it depending what your goal is.
Just giving a garage queen some love, getting a daily driver ready for winter, or somewhere in between?
Use a product like CarPro Eraser. Why I prefer Eraser over IPA is eraser has more lubrication.
Sent from my SM-N920V using Tapatalk
If paint is in good nick I just wash and apply the new wax. Don't overthink things.
My vehicles are coated, so if I want to prep them I use D114 @ 128:1 and call it clean enough, but for the most part I just spray whatever I fancy after I wash it.
How about a citrus wash followed by a paint cleanser. I use panel wipe myself by GTeqnique.
