J1nx93
- Jul 18, 2010
- 307
Okay guys, so the other week I ordered a Autogeek Chemical Resistant Pressure Sprayer with Double Barrel Attachment. I took it out of the box and stuff and put some water in it just to check it out in the kitchen sink. The sprayer itself is a good sprayer and has good pressure from what I could tell. I figured I'd take the Double Barrel Attachment and put it on and see if it worked too. With the normal sprayer nozzle on, you pump and press the trigger when you want to sprayer to spray. Well, I put the attachment on and started pumping it and it started spraying! I took it apart to check if anything was wrong and nothing was that I could tell. I was slightly angry that it would only work when pumped. Also if I pumped too much, it wouldn't stop unless twisting it off. The trigger was useless with the attachment on. So, is this normal? If it's not then it kind of irritates me by rendering the trigger useless. Hope you all could tell me if this is normal or not. I can make a video for everyone to look at if you don't get what I'm saying.
I'd just like Feed back please
