Pressure washer - $300-$600 Range
Thanks for all the input guys! I was just going off some charts I'd seen that list what PSI for what jobs. And I don't mind spending a little more for better quality tools that will last me.
I think I've narrowed it down to these two, leaning more towards the 3kpsi one.
Pressure-Pro PPS3030HCI Semi-Pro 3000 PSI Gas Cold - Water Aluminum Frame Pressure Washer w/ Honda Engine & CAT Pump
Pressure-Pro PPS2533HCI Professional 3300 PSI Gas Cold-Water Aluminum Frame Pressure Washer w/ Honda Engine & CAT Pump
If you're going to put that much into a pressure washer, go with the 2nd one. It has the Honda GX engine and is a superior engine over the GC engine. Just depends on what you're going to do with it. You're putting a lot of money into a PW that would probably be capable of waaay more than you'll ever need.
For car washing and around the house cleaning, either will do the job, but, some much much less expensive and durable PWs would do the same thing, however, if you've got the $$ to spend $700+ on a PW, go for the 2nd one.
