Thats BS. I have blasted plexiglass (Super soft) that was covered in sand on our houseboat. I did this a day after polishing it to brand new condition. After, i actually looked because someone told me exactly what you thought (not you personally, but a lot of ppl also believe this for some reason). No scratches, whatsoever. Also, i dont care how acidic, or basic a solution is, you won't ever break down sand. I work as a full time lab technician at a college, and have experience with extremely powerful acids and bases, so all the presoak will do (Maybe) is loosen up some of the dirt thats barely on there, it definitely won't dissolve anything. I agree with the person here who said that the foam brush is the most important tool at a car wash. Without some kind of friction, nothing will come off the car.If you skip the presoak option, and go directly to the high pressure soap, you are doing damage to you paint by water blasting the sand that on your car's paint. Basically you are sand blasting you paint and you will see the damage, first as hazing and in it's final stages as clear coat failure and missing paint.
Derrick said:David,
I did not attack your opinion. I merely disagreed with it and gave a factual example to support why I disagreed. BTW Ziggo99 was correct.
Derrick said:My knowledge does not come from washing cars, it comes from managing and maintaining one of the nicest and most technologically advanced self serve car wash in the country. A car wash that was designed to help ultra luxury and sports car owner's keep their own cars looking beautiful. Many of these people will not trust anyone with their cars, especially a detailer.
The owner spared no expense to make sure the cars in this area were able to be kept in immaculate condition. The only thing the users of the wash lacked was knowledge on how to correctly operate the equipment, and so did I when I was asked to work there years ago. I went to work there with one main objective, to correctly learn our chemical's manufacturer process so that I could correctly educate any customer who was willing to learn.
I don’t consider brushes, hand washing or power washing “brute force”. I can only assume your wash has brushes and rely on them to clean because like all other Coin-Ops, it’s a necessity. No matter how much science, physics and thought you put into your system; I highly doubt your set-up is much different that all the other ones that rely on brushes to totally clean their client’s cars and end ultimately ending up scratching them. Unless you’re monitoring the usage of each and every brush on each and every vehicle, inspecting them prior to and during their use, it’s highly unlikely that your system isn’t scratching up your client’s cars. Again, keep on thinking that…Derrick said:The thing I learned and it shocked me at first is that the modern car wash I worked at was all about science and physics. Brute force was not needed to clean the exterior of a car at that self serve car wash. By following the process, allowing the chemicals and machines to do their jobs, and using a little pressure on the hog's hair foam brush, washing a car without damaging the paint was much easier and acheivable. BTW, I never said we DIDN'T use brushes. You assumed that on your own. I didn't explain the whole process, just the step about presoaking which is equivalent to explaining why you clay a car before polishing.
Easily…yes. If someone was ignorant enough to get too close with and/or touch the vehicle with the wand then that could possibly damage something.
Neither. It’s the foam brush step. You can pre-soak a dirty vehicle all day long and it won’t remove the oily road film100%. Add weather change into the equation and it makes it even harder to safely clean a vehicle w/o bumping up the acid/alkaline levels. You can’t clean a dirty car @ a Coin-Op w/o using the foam brush step. Skip it and you’re car won’t get clean. Use it and you end up scratching the finish. If Coin-Ops could 100% clean a dirty car they wouldn’t have brushes there. When’s the last time you saw a touchless coin-op system? Especially in a northern environment.
You keep thinking that...
You’re way overboard with your opinion. I’d love to see any objective proof of this. If high pressure water hitting a dirty surface created damage, then every car on the road would get destroyed during a heavy rainstorm. Not to mention all the cars I’ve owned and maintained in the last 20 years by power washing w/o pre-soaking them. Not a single one has had any hazing, failure or missing paint from stone chips, better yet pressure washing them. I guess you have, so let’s see some evidence. I can’t wait to see your findings that are probably the biggest thing to upset the car wash industry yet……….
Sorry, but your example isn’t relevant, accurate of factual and like I said won’t clean a car 100% unless friction is incorporated. Wasting your time letting presoak dwell will surely kill your trim as well as everything else on the vehicle’s surface.
Case in point:
Besides my 20+ years of washing cars, I was also a part of a very unique multi-million dollar state of the art wash facility. I was partnered with the World’s 1st & only 25,000 square foot Indoor Do-It-Yourself 100% Nothin’ Touching Car Wash in the Metro Detroit area named Poly Pro Auto Wash. 1 of our 3 sites consisted of 13 indoor touchless self serve bays that were climate controlled year round and we supplied customers with In-Bay Vacuums, Multi-Purpose Cleaner, Tire Cleaner, Tire Dressing, Glass Cleaner, Drying Towels, Compressed Air & 10 scents of air Freshener all for no cost. We had the direct corporate support of Simoniz, Blue Coral, Stone Soap Company, CAT Power-Bright and a host of many others who assisted us in making sure the right combination of chemicals were used to clean cars to their fullest *possible* potential. I could go on forever describing all the challenges we faced with cleaning cars in the tough Michigan environment but don’t see the need at this crossing. Bottom line, there isn’t a Coin-Op car wash that can 100% totally clean a dirty car w/o using friction from the foam brush mounted on their wall. That's the big secret advice.
Glad to help. :xyxthumbs:DLB,
Thank you, this is exactly what I was hoping to see when I started this post.
Don
DLB
I do, but like I said "with the appropriate tip".How many detailers use a gas powered 2500 psi on paint, which has the potential to rip paint off a car, when most clearcoat paint applications don't need anything over 1200 psi to accomplish the job safely?
What would be a cost effective presoak chemical that is safe for paint rather than say a foam gun that could be applied with a pump up sprayer? For example, I know PB's Bug Squash can be used as a cleaner but I do not consider it cost effective.
ONR. I know its not a harsh chemical but it serves the same purpose as a presoak. It'll loosen and make removing dirt easier, without damaging the paint.
Derrick
