Problem working with Meguiar's M105 Ultra Compound?
Re: m105??
How does one know that he/she has the new and improved second-generation/low dusting formula of the M105?
So what you all saying is make sure the Pad is well primed and well coated... and then do a small square... and add some Water if required?
I'd like Mike to chime in on this subject and give his opinion, too... please.
Re: m105??
Look at the back of your bottle. If it says it compatible with a DA then you have the new version. Plus its been over two years now since the reformulation so I doubt anybody would still have the old version in stock.
Water helps only a little bit but not much. Using water/QD only lets you do at most an addition pass or 2 and after that you shouldn't really use anymore because as you re-lubricate the compound you clump the abrasives/abraded paint together and scour the paint more. Also using a squirt of water is with the KBM method is only really for the rotary and not DA.
Re: m105??
Thanks for the tip...
I just finished watching the Video of the new Optimum Hyper Polish Spray Compound... and it almost looks too good to be true.
Does anybody out there think that the Optimum Hyper Polish Spray is a good replacement for the woes of M105 ?
Re: m105??
I too would like to see a side by side comparison of these two products. Obviously M105 will work faster, however I am looking for a LOW dust product and OHPS would probably do that.
Re: m105??
The hyper polish spray will not come close to 105... the hyper compound spray came out and thats what i am interested in testing... Even if it works to 80% of what 105 does... thats 80% of the cars that you do not have to worry about sling and dust on... So i am testing it out next week when my order gets here
Keep in mind i am total spaz when it comes to the rotary... I just think more passes and more forgiving of a product will help me not et as frustrated when learning... just hope i dont develope ot many bad habits also
Chris
Re: m105??
A very good alternative to m105 is m95. It has a plethora of lubrication so it as a very good buffing cycle, low to no dust, and has the same cut but does not finish as well as M105(shouldn't matter since it has to be followed up with a light polish anyways.) Also M95 is designed for the rotary, but people have used it with great results on a DA.
Re: m105??
every time i use this it dries on my fist pass, i use w7000 pad on a pc set to 5 doing a 2x2 area anyone gets this? also its hard to wipe off
Just to double check, the W-7000 is an 8" pad, are you using an 8" pad on a Porter Cable Dual Action Polisher?
The W7207 is a 7" pad
The W7006 is a 6" pad
the W7204 is a 4" pad
Besides that, here are some tips to make working M105 easier...
IF you're new to machine polishing, try using a polishing pad first to get some experience behind the tool under your belt. A polishing pad is more pliable and will make working any product much easier than the Meguiar's cutting pads. The Meguiar's cutting pads are VERY stiff and this doesn't make buffing with them easier... what's the opposite of easier?
Then as you become more proficient with the tool and the product then try a foam cutting pad.
Also just to note, Meguiar's does NOT recommend using their foam cutting pads with DA Polishers, I should know, I wrote the copy for the Meguiar's on this recommendation.
That's too large of an area, I can't count how many times I've posted this but here goes again... a 2 foot by 2 foot area is too large an area for most paints, paint problems and people to work effectively with a DA style polisher and ESPECIALLY if you're doing serious correction.
The 5.0 speed setting isn't going to help for a large area and stiff cutting pad and a product with a known short buffing cycle either.
SHRINK THE SIZE OF YOUR WORK AREA DOWNWARD
In this video and in this article I recommend about a 20" squarish area and that's because a 2 foot area is usually too large and a 1 foot or even 16" square area is usually to small.
I'm pretty confident I've written more about this topic than anyone else in the detailing world and I'm pretty confident I've taught more people with "hands-on" training than anyone else I know of and a 2" area is too large for the pad, product, tool and experience level you're using.
Here's how to do a "Section Pass" when trying to remove swirls, scratches and other below surface paint defects.
How to do a Section Pass
[video=youtube_share;Q70g83mnTn4] - How to do a "Section Pass" with a Porter Cable 7424XP[/video]
The Definitive How-To Article for Removing Swirls, Scratches and Water Spots Using a Porter Cable 7424XP, G110v2 or Griot's Garage Polisher
From the above thread, read through the below and use it as a Check Off Sheet, make sure you're doing everything correct.
Correction work – Using the PC7424XP to remove below surface defects
  • Work small sections at a time
  • Make overlapping passes as you work the panel
  • Use a slow arm speed
  • Use the 5.0 to 6.0 Speed setting when removing below surface defects
  • Apply firm downward pressure
  • Don't over use or under use your choice of compound or polish
  • Hold the pad flat to the surface
  • Clean your pad often
  • Remove spent residue before adding fresh product
Dual action polishers that use a clutch, like this PC 7424XP are popular because they're safe. The reason they’re safe is because if you push down too hard on the head of the polisher the clutch will engage and the buffing pad will stop rotating. This will prevent you from burning through the paint and/or instilling swirls into the paint. Compared to a direct drive tool like a Rotary Buffer, this tool is dramatically safer in its manner of operation.
For this same reason that people love this style of polisher, (It’s safe and easy to use), you'll find out right away that it also limits you to only working small sections at a time in order to remove enough paint to level out the surface and remove the defects. In most cases you're only going to tackle a section about 16" to 18" inches square or so; usually a 2' section is too large and a 1' foot section is too small, so you'll want to find a balance between working too small an area and working too large of an area at one time.
Since you can only work small sections at a time, this means you’ll need to break each panel up into small sections kind of like Checkerboard or Patchwork Quilt.
That is you’ll take each panel of the car, (a panel would be a door or fender or the hood), and in your mind’s eye slice it up into dedicated sections approximately 16" to 18” squarish or so. Because not all panels are perfect squares you’ll need to let the panel be your guide and break-up each panel into these smaller sections no matter what the shape may be. What’s important is to only work a small section at a time while using overlapping passes to work your product.
The average size hood will be broken up into either 4 sections for a small hood, (Mini Cooper), or 6 sections, (Honda Pilot), or 9 sections, (Ford F150).
This isn't a hard and fast rule as softer or more workable a paint means you can tackle a larger section at a time and conversely, with harder paints, or less workable paints you'll want to shrink the size of your work area down.
The idea being to match the size of the section you're working to the workability of the paint, which you should discover when you do your Test Spot, which is addressed in this article. Experience helps a lot with judging work size area but the only way to get experience is to put some hours behind the polisher on multiple cars.
Spread your product out first
To start, place the face of the buffing pad with the product on it, flat against the paint. Then turn the polisher on and quickly spread the product out over the entire section you're going to work. You can do this rather quickly because at this point you're not trying to remove defects; you’re just trying to spread the product out over the paint so that you have a uniform film of product spread out over the section.
Overlap your passes by 50%
After you spread the product out, now it's time to slow your Arm Speed down and begin making overlapping passes usually in a crosshatch or back and forth, side-to-side pattern.
The goal is UMR, that is Uniform Material Removal.
The reason for this is so that you remove an equal amount of paint over each section and in turn over the entire car. In order to do this you need a method that you can control and duplicate and for most people following a back and forth, side-to-side pattern works because it’s easy to remember, easy to do and easy to duplicate.
The definition of a pass
There are two definitions of the word pass as it relates to machine polishing with any type of machine.
Single Pass
A single pass is just that. It's when you move the polisher from one side of the section you're buffing to the other side of the section you're buffing. That's a single pass.
Section Pass
A section pass is when you move the polisher back and forth, or front to back with enough single overlapping passes to cover the entire section one time. That's a section pass.
Like this,
In most cases if you're removing any substantial below surface defects you're going to make 6-8 section passes to the section you’re working before you either feel comfortable you've removed the defects or you're at the end of the buffing cycle for the product you're using.
Buffing Cycle
The buffing cycle is the amount of time you are able to work the product before the abrasives have broken down, (if you’re using a product that uses diminishing abrasives), and/or the product begins to dry and you lose the lubricating features of the product. Different products have different buffing cycles depending upon the type of abrasives used in the formula and the different ingredients used to suspend the abrasives and provide lubrication.
Factors that affect the buffing cycle include,
  • Ambient temperature
  • Surface temperature
  • Size of work area
  • Type of machine
  • Type of pad material
  • Humidity
  • Wind or air flow surrounding the car
  • Amount of product used
  • Technique
Wet buffing technique
Most compounds and polishes should be used so that there is enough product on the surface to maintain a wet film while the product is being worked. The wetness of the product is lubricating the paint as the abrasives abrade the paint and cushion or buffer the abrading action so the abrasives don’t simply scour the finish leaving behind swirls and scratches.
Dry Buffing Technique - Buffing to a dry buff
There are some products on the market where the manufacture recommends buffing the product until it dries. As the product dries you’ll tend to see some dusting as the product residue becomes a powder and the paint will have a hard, dry shine to it.
Although some manufactures recommend this, it’s important to understand what’s taking place at the surface level as you buff to a dry buff. As the product dries, in essence you are losing the lubricating features of the product and as this happens friction and heat will increase. As friction and heat increases, so does the risk of micro-marring the paint or instilling swirls either by the product residue or the pad material and/or a combination of both.
While we trust that the manufacture knows their products best, when we take a close look at what it means to buff on a delicate surface like an automotive clear coat, it doesn’t make sense to run a buffing pad on top of the paint without some kind of wet film to lubricate the paint at the same time. We always recommend that you follow the manufacturer's recommendations and use your own judgment.
Everyone new to buffing wants to be told some easily identifiable sign that they can use to tell when it's time to stop buffing and it's not that simple, so here's an indicator I've always used and taught to others,
Wet film behind your path-of-travel
As you're making a single pass with the polisher, the paint behind the path of travel of the buffer should have a visible wet film on it. If the paint behind the pad is dry and shiny, you've run out of lubrication and you're dry buffing. Turn the polisher off. Wipe the residue off and inspect using a Swirl Finder Light to make sure you didn't dull or mar the paint, you usually won't cause any harm, but pay attention when your running the polisher and don't buff to a dry buff. If you do, you can quickly re-polish that section by cleaning your pad and adding a little fresh product and making a few new section passes.
The speed at which you move the polisher over the paint is called your arm speed, that is how fast or slow you move your arm which is controlling the polisher. When removing below surface defects like swirls and scratches you need to move the polisher slowly over the surface, not quickly. This has to do with the hardness or workability of the paint and when it comes to modern clear coats, generally speaking,
Modern clear coats will tend to be harder than traditional single stage paints.
This isn’t 100% true all the time as I’ve worked on some very soft clear coat paints, but more often than not this is the norm. Another way of saying this would be,
The paint on a brand new Mustang will be harder than the original paint that came on a 1965 Mustang.
This has to do with how modern paints are chemically made, sprayed, baked, and cured onto the car’s panels. Modern paints tend to last a long time as compared to paints from the 1950’s, 1960’s and 1970's and part of the reason they are more durable is because they are physically harder than old style solvent-evaporation paints, thus they resist deterioration better than old style paints. And while everyone wants a paint job that will last a long time, it is this hardness factor that makes it more difficult for you and me to remove defects like swirls and scratches out of the paint because it’s physically harder to remove small particles of paint off the surface both by hand or machine. This is one of the main reasons so many people get so frustrated trying to remove swirls out of the clearcoat paint on their new cars, trucks and s.u.v.s.
It’s for this reason you need to move the polisher slowly over the surface, you need to give the buffing pad, the oscillating/rotating action of the polisher and the abrasives in the product under downward pressure time to affect the paint in one area before moving it forward to new territory. If you move the buffer too quickly over the paint you won’t remove any defects because you won’t remove any paint.
A personal note, maybe you can relate...
Even though I've been machine buffing cars since the early 1980's, and teaching people how to use machines since 1988, and a part of this is teaching people to move the polisher slowly when removing defects, each time I start a new project I'll find myself instinctively starting out by moving the polisher too fast.
My theory on why I do this and why so many other people do this is for two reasons.
1. When you turn the polisher on at the 5.0 and 6.0 speed setting, it sounds like the motor is spinning really fast, (it is), and this sound has a psychological effect that makes us want to move the polisher fast. I find I have to purposefully slow down how fast I'm moving the polisher over the surface.
2. Buffing out a car from start to finish takes a long time and the biggest chunk of time is the cleaning and polishing step where the defects are being removed. It's easy to think that if you move the polisher faster then you can do the job faster, but this just isn't true. Fact is if you move the polisher fast over the surface you're really not doing anything but wasting time. It's another case of moving slower in order to go faster. (That's what you want to do)
Speed settings for removing below surface defects
The variable speed dial on the PC 7424XP offers 6 speed settings from 1 to 6. For most car detailing projects you’ll use these speeds.
  • 5.0 to 6.0 to remove defects
  • 3.0 to 4.0 to apply and spread a layer of wax or a paint sealant
  • 5.0 to 6.0 to remove dried wax or paint sealant using a microfiber bonnet
Removing below surface defects means removing a little paint. In order to remove a little paint you need the pad rotating against the paint under pressure with an abrasive product. In order to do this you need to use the 5.0 to 6.0 speed setting. This applies to any steps where you’re removing paint. This would include a heavy compounding step, a final polishing step, or working a cleaner/wax over a neglected finish.
For removing below surface defects use the 5.0 to 6.0 Speed Setting
After the defects have been removed and you’ve worked the paint up to a clear, high gloss you no longer need or want a fast rotating speed as you’re no longer trying to remove paint, so the 5.0 and 6.0 speed settings are too fast.
The exception to this rule is if you’re using a cleaner/wax on a neglected finish as a one-step approach. In these situations you need the high speed to keep the pad rotating to work the cleaners in the cleaner/wax to clean the paint and remove light defects.
When it comes to applying a finishing wax or paint sealant the goal is to spread the product out and work the product over and into the paint to whatever level is possible. For this the 3.0 to 4.0 speed setting works best. Anything slower than 3.0 is just too slow and your buffing pad will tend to feel like it’s dragging across the paint as you move the polisher forward. When applying a finishing wax or paint sealant, a good rule of thumb is to make 2-3 single passes over each square inch.
Some people like to remove dried wax or paint sealant using a microfiber bonnet over a buffing pad. When using the dual action polisher like this you need the pad to rotate and thus you need the higher 5.0 to 6.0 speeds. Just be careful to never lift your polisher off the surface with the motor turned on as the buffing pad will spin up to maximum speed and your buffing pad and bonnet will fly across the room and land on the floor. (Usually the dirtiest part of the floor and with the bonnet face down)
For removing below surface defects you need to apply firm downward pressure to the head of the polisher. As we discussed earlier, removing below surface defects means removing some paint off the surface and this requires applying some pressure to the head of the polisher to engage the abrasive particles with the paint so they can take little bites out of it.
This is where hand-on training comes in real handy by someone with years of experience but I'll try to explain it with this keyboard.
15 to 20 pounds of pressure
If you place the face of the polisher on a normal household bathroom scale, it will read around 4-5 pounds, so just the weight of the polisher itself is supplying some downward pressure.
Now follow me, if you apply just LIGHT pressure to the head of the polisher to keep the pad flat and stable while it’s operating, you’ll be around 7-8 pounds of downward pressure right from the get-go. If you apply even more pressure to really engage the pad and the abrasives against the paint you can easily reach 15 to 20 pounds of downward pressure.
I know when some people read this it sounds excessive but it’s really not when you consider the pressure by just the weight of the machine already is around 7 pounds of pressure, and with just light pressure you’re already at 10 pounds of pressure.
Take my word for it, when trying to remove a little paint from some cars it’s going to take some downward pressure to engage the abrasives into the paint and do any serious correction work. The key is to remember that polishing paint is an art form and anytime you have to use an aggressive approach to remove a little paint chances are good you’re going to have to do a follow-up step to refine the finish even further using a less aggressive pad and product. So the results from an aggressive product with downward pressures of 15 to 20 pounds won’t always leave a pristine finish but that’s okay, you’re not finished yet. (No pun intended)
As a general rule of thumb, when working on seriously neglected paint, you'll want to apply firm pressure but never so much that the pad stops rotating. This is the purpose of the black lines on the back of your backing plate and/or foam buffing pads, it’s so you can easily see if your pad is rotating or simply vibrating against the paint. Paint is removed best when the pad is rotating, not simply vibrating.
Keep in mind you need to balance how much pressure you apply to the condition of the paint and what you’re trying to accomplish. If the paint is in good condition and only in need of light correction, (shallow defects), then you won’t need to apply as much pressure. If the paint you're working on looks like it's seen a Destruction Derby, then increase your pressure to anywhere from 15 to 20 pounds of pressure.
It's vital that you hold the buffer in such a way as to keep the pad flat against the surface while you're buffing. With a completely flat panel like the hood of most large cars and trucks, for example a 80's era Suburban, it's pretty easy to keep the pad rotating by holding the buffer evenly as you buff.
With panels that slope or curve, you need to rotate or adjust how you hold the body of the polisher to match the curve of the panel as you move it over the paint.
If you hold the polisher in a way that there is more pressure on only an edge of the buffing pad, this increased pressure to one section of the face of the buffing pad is enough to stop the pad from rotating. This will be easy to see from the marks on your backing plate and paying attention to how you’re holding the polisher in relationship to the shape of the panel. Watching your pad will help you to perfect your technique.
It's not as difficult as it sounds and most people new to using a DA Polisher will learn how to hold the polisher while adjusting for the curves and slopes of the car after buffing out just the front clip of their car, (hood and front fenders). The learning curve for a DA Polisher is pretty flat, that means it's pretty easy to learn how to use.
Use an ample amount of product
When we say use an ample amount of product this means don’t use too much product and don’t use to little product.
Too much product
If you use too much you can hyper-lubricate the surface and this will make it more difficult for the abrasives to abrade the surface as they’ll tend to want to glide or slip over the surface instead of bite into the surface.
To little product
If you use too little product there won’t be enough lubrication to enable the buffing pad to rotate and thus engage the abrasives against the surface so they can bite into and remove small particles of paint.
Learning how much product to use varies with manufactures products as there’s a lot of variables involved. The best teacher is experience coupled with any hands-on training you can find. Watching a video or asking questions on a detailing discussion forum like the Autogeek Online Detailing Forum is a great resource for this kind of information.
Also, when you’re first starting out with a dry pad, (doesn’t matter so much if it’s new or used as long as it’s clean), the pad will tend to absorb some of the initial product applied to it or picked up off the surface. As you continue to buff and the pad becomes more wet or saturated with product a couple of things will take place:
You’ll find you’ll need less product to work a section. As the pad becomes wet with product, the combination of liquid and foam will tend to absorb and dissipate the power provided by the motor. This will show up as a reduction in the ability of the tool to keep the pad rotating under pressure. Then if you apply more pressure the clutch will engage and the pad will stop rotating. The fix for this is to clean your pad often, which we will address below and/or switch to a fresh, clean, dry pad and continue switching to clean dry pads as you work around the car and your products become wet with product.
Of course the ability to swap out pads means having a collection of pads in your arsenal to start with depending upon your budget and how much you value your time. Simply put, dry pads rotate against the paint better than wet pads, so it’s faster to buff out an entire car by swapping out wet pads for dry pads versus trying to buff the entire car out with only a few pads.
New generation DA Polishers like the PC 7424XP and the Meguiar’s G110 offer more power than their predecessors and this is their strong point because it’s this extra power that will keep your pads rotating better even after they become wet with product. This one feature alone makes them worth choosing over earlier dual action polishers and/or upgrading.
Anytime you’re buffing with an abrasive product, whether an aggressive compound or a light polish, you have two things building up on the face of your buffing pad,
  • Spent or used-up product
  • Removed paint
You need to remove these residues often by cleaning your pad either with a,
  • Pad washer
  • Pad cleaning brush
  • Terry cloth towel using a technique called cleaning your pad on the fly.
Again, we cannot stress enough the importance of working clean and in this case it means wiping any spent product off the paint after each section pass and removing any spent product and paint residue off the face of your buffing pad with one of the three methods listed above.
If you don’t clean your pad often then usually you’ll find that your product will become gummy on the surface of the paint and wipe-off will become more difficult. Not only that, but as product residue builds-up on your paint you increase the risk of instilling swirls back into the paint.
Adding fresh product to used-up product dilutes and pollutes the fresh product, making it less effective. So make it a best practice to clean your pad often and always wipe off spent product before adding fresh product.
How often to clean your pads?
Car body panels
At a minimum, wipe all spent product and paint residue off the car after you finish each section and always wipe the paint clean before re-polishing that section a second or third time with fresh product.
Buffing pads
This is personal preference and here’s what I do, for the average condition paint I will tend to clean my pad on the fly every other application of product. This means if I were buffing out the hood of a car I would apply my product to the face of the pad and buff out a section of paint about 20” square or so. If I’m done with that section I would wipe the residue off and then buff out the next section and be sure to overlap a little into the previous section. Now, after I’ve buffed these two sections I would clean my pad on the fly and then start on a new section and repeat this method as I work around the car.
If the paint is severely neglected and I have to really get aggressive with the paint then I would clean my pad after each application. Also, if the temperatures are hot then I would clean my pad after each application as this will make buffing easier and more effective with less problems associated to the product trying to dry and/or become gummy on the surface.
If you have a pad washer then you can follow this same routine. The most effective way to clean a pad while working on a car is by placing the pad on a rotary buffer, (even if you’re not using a rotary buffer to do the buffing work), and use the direct drive rotating action the rotary buffer offers to spin the pad in the pad washer at high speed and under pulsating pressure to really get the pad clean. Then lift the pad up a few inches and bring the rpm’s up to the buffer’s highest speed and spin out all the water via inertia. Now your pad will be clean and ready to get back to work.
I have a detailing class coming up on July 31st, attend the class and get these kinds of results...
Proof You Can Do It! - Joe The Detailer - Black Porsche Turned into Black Pearl!
"Joe the Detailer" This is the first car he's ever machine polished, a black Porsche and this was done 3 days after attending a Saturday Class!
Your car can be a show car too... we can show you how!
If you're working a 2x2 area on speed 5 and buffing till it dries then it's going to be hard to wipe off.
  • Shrink your work area down.
  • Spread your product out over the area you're going to work like I show in the video as soon as you turn the polisher on.
  • Use the tips and techniques ins the above article and video and you should see success.
:dblthumb2:
Here's some more thoughts on the issues brought up in your post...
Meguiar's Foam Cutting Pads (Not recommended for use with a PC)
The foam used to make the 7" pad is different than the foam used to make the other maroon foam cutting pads in the cutting pad series, it's a little softer.
All or at least all the foam cutting pads I can think of are more dense or stiffer than polishing pads and finishing pads and this lack of pliability will tend to add to the difficulty of working with M105 until the pad becomes more pliable and that happens when it becomes more damp, either with the addition of a pad conditioner or with product build-up.
Shrink the size of your work area down to a smaller size
Anytime a product becomes difficult to work with one tip you can try is to shrink down the size of your work area, this means you spread the product out over a smaller area and because you're engaging the working film of product over the area more quickly as you move the polisher there's less time for the product to dry.
Thought this would have been addressed at SEMA last year?
I too have found M105 to dry too quickly and somewhere on this forum I posted a comment that one of my surprises at SEMA was that we didn't see a new and improved version of M105 introduced to solve this problem. Forum consensus on multiple detailing discussion forums which is the opinion of a lot of different detailers over a wide spectrum of working climates and environments all result in the same observations about the product and that is that it has too short of a "Buffing Cycle" for most people and most applications.
M105 is designed to remove #1200 grit sanding marks in a body shop situation, I always ad the extra part about "in a body shop situation" because there's a huge difference in removing sanding marks out of brand new, fresh paint, as in days old and removing sanding marks out of factory baked-on, case-hardened finishes.
One of the things that made and makes M105 unique in the compound world is that it is a very aggressive compound yet correctly worked it will finish out to a very high gloss, low swirl finish, which in years past was not the norm for an aggressive compound.
How does it compare to Optimum's Compound II?
No comparison on buffing cycle, the Hyper Compound will buff for insane amount of time with no gumming, drying or dusting. Hyper Compound is designed to remove #1500 grit sanding marks on fresh paint so it's not as aggressive but most body shops finish sanding at #2000 grit, some might finish sanding at #1500 but I can't remember any shop that finishes at #1200, it might happen as this is a personal preference factor but most shops will finish sanding at a higher grit level, not a lower grit level.
My personal opinion is that it's faster "overall" to finish sanding at a very high grit level, for example #3000 or #4000 as this will make the compounding step faster, more effective and introduce less heat to the paint. Heat is never a good thing although for years I've seen people post that heat is necessary to break down abrasives when that's not true, what's needed is pressure over time. Heat is an unwanted and unnecessary by-product of the process.
I've used M105 a lot, I was at Meguiar's when it was introduced, in fact the thread that introduced it to the forum world was posted by me and we used the M105 and M205 in all the Advanced Classes on Wetsanding, Cutting and Polishing while I was at Meguiar's and they continue this to this day. So I'm very familiar with the product and I don't have the problems with the product that are commonly posted about on forums such as this thread but technique is also a huge factor in product performance.
I've posted on this forum since I arrived here just about a year ago that it's vitally important to work clean and that is very true for M105, this means cleaning your pad often and often can mean cleaning your pad after each Section Pass whether you're working with a DA or an RB. The warmer or hotter the temperatures, the worse the working conditions then the more often you want to clean your pads.
When cutting with a wool pad on a rotary buffer it really helps to have a pad washer, but if you don't have one you can get by with a Spur.
When cutting with a DA Polisher you can get by with "Cleaning your pad on the fly"
using a terry cloth towel, but a pad washer will clean a foam cutting pad better. Of course you can always switch to a new pad or a clean dry, used pad.
Keep in mind that anytime you us ANY product that abrades the paint, you will have two substances building up on the face of your pad,
  1. Spent residue
  2. Removed paint
Both of these need to be removed as they build up before adding new product and continuing with the buffing process.
You also want to wipe off any residue from the area worked before adding fresh product if you're going to work the area again.
Anyone having this problem should be sure your surface is cool and out of direct sunlight :buffing:
Correctamundo....
Often times on threads like this it can be all to easy to "assume" a person is working on a cool surface in the shade but if the OP doesn't include this kind of detail in their post then it should be brought up.
I'm always surprised how often a person will start a thread and tell us everything they're doing and leave out the "tool" they're using.
Hope the above helps a little...
Re: m105??
Thanks for the PM, yesterday being Sunday and a holiday, I was recharging my batteries...
The above reply is almost 6000 words... hopefully if nabisco can wade through it and try some of the suggestions we can see him through to success...
:xyxthumbs:
mr PHILLAPS thank you again for taking the time to write this post i will try to avoid the cutting pad and use a megs w8006 pad thanks again
Re: m105??
Just found this thread and am wondering, where can I get some more info on how M105 was designed to work? I did the tailgate of the truck as a test and I was amazed at how quickly it dried/dusted. Eventually I was adding distilled water which after reading this entire thread to this point, seems to be counter-productive. Even though it dried quickly, after finishing with 205 (which is a dream to work with), most of the swirls were eradicated. I'm not giving up on M105 because I've only had like 5 passes with it but I was wondering if my problem was with my choice of priming product (started out with Pinnacle pad conditioner and then moved to distilled water). Any links regarding M105 to educate myself? Everything in my arsenal is Menz except for the M105/M205 that I recently tried.
DA and M105 on a 6" white CCS pad, M205 on a 6" black/gray CCS pad.
Maybe read through what I posted for the OP, (OP stands for the "Original Poster" or the guy that started the thread).
The reason you like M205 is because it has a loooong buffing cycle and easy wipe off, this is the opposite reason of why you and others dislike M105, shot buffing cycle.
  • Work in the shade on a cool surface
  • Shrink the size of your work area down
You want AMPLE amount of product when first starting out because you pad is dry and some of the product is going to seep into the pad leaving less on the surface to LUBRICATE and ABRADE the paint.
So a good rule of thumb that has worked for THOUSANDS of people over the decades is st start out with either a Circle Pattern or X Pattern of product on the face of your pad. I tend to prefer a Circle pattern as a habit because as you work around the car you'll find that your product will migrate to the center on it's own, so I don't help it by using an X pattern.
Spread the product out over the entire face of the pad
Another great method is to borrow from Kevin Brown's Method and that is to take your finger and spread the product out over then entire face of the pad so that when you first turn the polisher on the entire face of the pad is working for you.
I find from years of experience that by the time you do 2-3 "X-Patterns" or 2-3 "Circle-Patterns" and then simply go to work ALWAYS spreading your product out over the area you're going to work IMMEDIATELY, then in essence by the 2nd to 3rd time you do this the entire face of your pad is wet with product and you accomplish the same thing, (more or less), just by making sure that with each fresh application of product you spread it out over the area you're going to work before slowing down and making your "Section Passes".
In fact if you buff out 2 - 3 sections and turn your buffing pad over you'll see the entire working face is equally damp with used product...
It's when you spread the product out quickly over the area you're going to work that you spread out and leave behind on the surface of layer of un-used product that you then pick up as you begin to work the area that helps to ensure that the entire face of your buffing pad becomes wet with product.
Bad technique would to to place some product on the face of your pad, place the face of you pad against the paint and then turn the polisher on and start moving the polisher slowly making over lapping passes. The problem is you'll push a lot of that product up into your pad and you'll do most of the correcting at the beginning and less towards the end of the section you're buffing. So first, spread the product out quickly and then slow your arm speed down and start making overlapping passes.
After your pad is broken in with product, clean your pad after each section pass and when you apply fresh product you can cut down on the amount of product you actually apply to the face of your pad. Someone in this thread said 3-4 dime size drops, I usually place about a 2/3rds circle pattern to the outer face of my buffing pad and get back to work. Remember you want enough product on the surface so you have,
A) Abrasives working for you
B) A lubricating film keeping and maintaining a wet film between the paint and your pad.
Often times if you don't have enough product you'll end up buffing to a dry buff and when you lose lubrication what increases? Friction.
Hope this helps...
Thank you Mike. I only had time to skim-read your reply earlier and am waiting for after work to read it thoroughly.
Just like when I tried Menz products for the first time I initially had issues with using them and now that I've worked on my technique and gathered more info on how to use them efficiently, I have no issues with them and am not afraid to use them at all.
Since I'm so new to M105 (only did 5 passes with it), I'm suspecting my technique again and how to use them so that I can minimize the issues I'm experiencing. I place 100% of the dissatisfaction with what I AM DOING not the product itself.
Thank you so much for the input, info, how-to's and replies. I'm going to read them in detail when I get home.
Re: m105??
Dean,
I was thinking along those same lines.
I think it's fair to say that allot of us here are hobbyists or lets say "professionals in training". We tend to follow allot of the guidelines set forth by those more experienced and due to this we sometimes run into trouble because of that lacking. The more we use these products the more we understand how they're supposed to work but most of us are not up against the clock and our time is not necessarily money.
I watched Mike Phillips demonstrating the Optimum Hyper Polish Spray and I too was impressed. Naturally I was impressed with the final results but more impressed with how easy it was to use. It did take longer than Meguiar's M105 however in my opinion that may not be a bad thing more most of us, or at least me!
I'm going to give the Optimum Hyper Polish Spray a try and see if it works as easily and as well as shown. While it may not be "better" than Meguiar's M105 it just might be better for me..:buffing:
Re: m105??
Dean,
they make a hyper compound spray also that will get you closer to 105 in terms of cut but not quite there from wait i have read
