Wow looks amazing my friend. That finish is flawless beautiful work. An SRT with a concours finish. Id like to try some of that rust prevention grease, do you apply it or go to a shop for it?
Nice review, and great job. I must have missed it when you first posted.
These are a foam pad, correct?
I would assume they are fairly stiff/firm for the leveling. I tried their Flash pad and liked it, and it was pretty stiff/firm.
I destroyed it polishing out my sisters wheel that she used a steel pot scrubber on. Worked great and was thinking of getting a handful of them or maybe the orange peel ones for hitting bad areas first.
If we polish multiple times with a normal polish pads, let's say in the lifetime of our vehicle, will the orange peel disappear over time?
I think that these pads as well as the sand pads are the shorter and more aggressive ways to remove the orange peel.
Or using these pads is the only way to remove this kind of defects?
Foam pads follow the contours of the Orange Peel and will not effectively level OP.
Yes, the Denim Pads will level OP, but the end result is not as laser flat as using 1500 grit sanding discs followed by 3000, Compound & Polish.
The Denim Pads can generate a lot of heat and can twist paint.
You need to be just as careful as you would be when sanding. Ridges and Edges can bite you quickly.
I heard from another Jeep SRT8 owner (who did the same orange peel removal process) that the velvet pads worked slightly better than the denim for the factory clear.
Has anyone used the Carpro velvet pad to remove factory applied orange peel? I have a white 2004 Dodge Ram. According to my reading of this particular pad, this is the one I should use. Please advise which to use, Carpro denim or velvet
