Product Review: Meguiar’s D110 Hyper-Wash
Guess I know which is my next soap, thanks for doing my legwork Troy :dblthumb2:. That said I love Lusso but find myself using it rarely because of its cost.
Bumping up an old thread.
What is the recommended dilution for use with a foam lance? The can says 400:1. Is this for normal wash or foam Lance?
For what its worth...I put 3oz product in a 32oz canister and fill the rest with water.
Well it's not exactly cheap here in India since it's an import. Costs little over 40 dollars here. So cant be so generous with the product.
What silverfox said is true.
3oz and fill it up :)
Your lucky... It cost well over 60 bucks here lol
When I use D110 in a foam gun or lance I usually only use 2oz at most. But this isn't an aggressive TFR soap like they have over in the EU. So I use it more to soak and add additional lube to my wash process. I have not found that any regular car soap cleans a car just by spraying it on and rinsing it off. They help, but my pressure washer does most of the work IMO.
The cost thing is an issue that each person will need to figure out for themselves. But I would guess that what I would consider other more expensive soaps translate and are more expensive in other areas as well.
Will try with 2 Oz. It results are not satisfactory then will increase to 3oz.
Like troy has mentioned, foam Lance is only for pre wash. It will be followed by 2 bucket method
2 ounces worked very well for me with D110. Great soap.
Funny how meguiars has omitted mentioning the dilution for Foam Lance when the product is majorly used with foam lance.
