luckydawg
Active member
- Jan 19, 2016
- 1,117
- 1
If its in the clear-- he can.Why can't he wet sand the clear and then polish?
But if its in the primer---
Not truethe color and clear would have filled it.
Not true
Seen it MANY MANY times
Looks like it was in the clear though
Nope-- not saying that at all. Most body shops dont finish primer with 800G-- they finish with more like 320 or @ best 400. High $ custom paint work or folks that do it them selves might sand the primer with 800G-- but the over whelming vast majority of body & paint shops will be using 320 on the primer. Remember-- we are talking about the primer.Are you saying if they sanded the primer with 800g and then shot the base color coat and then the clear, you would see the sanding marks from sanding the primer?
What post # did you read that they finished the primer with 800G ?
