Nick McKees37
McKee's 37 Product Support
- Jan 6, 2011
- 7,265
We're all ears when SONAX, one of Germany's largest and most respected manufacturers of car care products, introduces a new product. Late last year I got a sneak peek at Rim Shield, a high-tech polymer coating that blankets your vehicle's wheels in a glossy layer of protection that makes cleaning much easier. If this product sounds familiar, it's because you saw it on an episode of Competition Ready on Velocity Network.
Before we jump right in, what exactly is SONAX Rim Shield?
SONAX Rim Shield is best described as magic in a can! This high-tech polymer coating is a FAST and EASY way to protect your wheels against the damaging affects of brake dust, road grime, dirt and oil. By blanketing your wheels in a super slippery, self-cleaning coating, SONAX Rim Shield actually works to keep your wheels cleaner in between regular washes. Speaking of washes, all you need to clean wheels that have been coated with SONAX Rim Shield is a mild car wash detergent, such as SONAX Gloss Shampoo. Spray on and walk away!
I sat down (figuratively) with Rob McCrary, Managing Director for SONAX, and asked him a few questions about SONAX Rim Shield:
Nick: I’ve been fortunate enough to have been using SONAX Rim Shield for several months now, but for those that have NOT used Rim Shield, can you please explain how it differs from SONAX Polymer Net Shield?
Rob: It is the same basic technology behind the two but the Wheel Rim Shield withstands the integrity of the product much better than Polymer Net Shield due to the heat of the rims/wheels. Polymer Net Shield is not designed for the extreme heat some wheels generate and begins to break down much quicker.
Nick: Approximately how many wheels will one can of Rim Shield coat?
Rob: Germany was adamant that we put 12 rims on the label. My experience has been several more than that - maybe 20 or so.
Nick: What’s the expected durability of Rim Shield?
Rob: 6 weeks but it is recommended to reapply with every wheel cleaning. When done this way, cleanings are much, much easier.
Nick: Can it hold up to strong wheel cleaners like SONAX Full Effect?
Rob: Again, it is recommended to reapply after every wheel cleaning but can/will hold up again strong non-acid wheel cleaners. Obviously, acidic wheel cleaners will remove anything off of the wheel.
Nick: What’s the best way to maintain wheels that are coated with Rim Shield?
Rob: SONAX Car Shampoo and water. If desired, either of the SONAX Wheel Cleaners can be used as well. A strong water source can also be used to remove break dust that has not attached to the wheel.
Nick: Last question: What was the biggest challenge in developing Rim Shield?
Rob: From my understanding, developing something that did not need to be touched after applying was the difficult part of development. This allows for a safe and extremely easy application process unlike anything else on the market.
Thanks Rob! :dblthumb2:
Shop SONAX Rim Shield at Autogeek
Click HERE to read Mike's review/how-to of SONAX Rim Shield
