Your 3" Griots is ideal for the sanding phase of headlight restoration
You just need to add a Meguiar's 3" Foam Interface pad, so that the sandpaper discs will conform to the headlights better
I heard the GG 3" would work well for sanding them down but what about buffing out the sanding marks and polishing? I know the GG doesn't have enough you power for that or it will just take forever.
Go all the way up to 5000 grit sanding. Do you have a PC or other larger (than the GG 3") DA? I sand with the GG 3" and then polish with a PC with a 4" pad. I know the GG is wimpy but it may be fine for polish after the 5000 grit sanding, I haven't tried it that way though.
