Question about maintaining Carpro Essence
Eldorado2k
I've got a good friend who I've converted into using Megs D115 from traditional bucket washes and he's really happy with the convenience & results he gets. But his choice of microfiber towels may not have best, which has resulted in minor swirls gradually being inflicted back onto his paint. His car still looks good, but I'm pretty certain it's due for a proper decontamination and I'd like to try Essence for the 1st time on a vehicle like his, because I know he'd be really excited with the best results possible.
But since I already know he'll be using D115 not too long after the detail, I'm thinking of just using Essence as a stand alone. Does that sound ok? Will using a waterless wash & wax such as D115 @4:1 dramatically affect the recently applied coat of Essence so much that it should be avoided?
Will be fine.
Pulled straight from CarPro's site. Enjoy the read.
CarPro is turning the wheels of innovation once again!! CarPro Essence is a unique blend of nano-tech Quartz, high gloss durable resins, and fine abrasives that are blended together at a microscopic level to form something truly ground breaking! CarPro Essence leaves an amazing high gloss finish with semi-permanent fillers and protective capabilities all built in!
Paired with a microfiber cutting pad Essence is capable of unexpected cutting power, while a CarPro gloss pad armed with Essence provides gloss we could only dream of until now! But this is not simply a polish…
In less than the time you take to polish a car with conventional products, CarPro Essence is capable of removing swirls, building your clear coat thicker, leaving higher gloss, and laying down a semi-permanent coat of protection! Oh… and it wipes off like a dream!
Incredibly Essence also leaves a perfectly smooth, deep, reflective, primed layer to build on with CQuartz or Reload! The primer attribute in Essence makes application of CQuartz easier than ever and bonds together seamlessly, forming a shell of Extreme Gloss and protection!
Features:
Primes surface for CQuartz or Reload
Produces Extremely High Gloss
Semi-permanent filling capabilities
Adds layer of Sio2 Quartz protection
Use with D/A, Rotary, or by Hand
Prep:
Wash, decontaminate, compound and prep vehicle for polishing
Directions:
Shake well
For more cut use Microfiber cutting pad and prime well
For finicky and soft paints use microfiber pad
For maximum gloss use sparingly with CarPro Gloss pad
Spread evenly across section on low speed
Polish on medium speed
Clean pad often
Clean pads ands towels immediately after use
Questions & Answers from the forum:
1 - What is CarPro Essence?
CarPro Essence is a semi-permanent sio2 extreme gloss enhancer, finishing polish, primer, and coat in one.
2 - Do I have to use Eraser between Essence and CQuartz?
If your using Essence by machine and you wait until the vehicle is finished then you can apply Reload or CQuartz after you finish the vehicle starting in the same direction you polished. If you want to be ultra safe you can still Eraser but in our testings to date we have not seen any failure when we skipped Eraser.
If your using Essence by hand then we recommend you use Eraser before coating.
3 - How long does CarPro Essence last?
We expect 1 year on its own BUT we recommend applying reload or CQuartz over top for the much better hydrophobics and dirt resistance. This will provide 115+ Degree contact angle instead of 90 deg contact angle (not so good) with Essence alone.
4 - So, I can use Essence with CQuartz?
Yes, any CQuartz coating and any of our CarPro Nano sealants like Reload it will work great.
5 - How does it work if you use it between the paint and CQuartz?
It bonds to the paint, the CQuartz bonds to it and merges. The Sio2/resin in it are heat activated by the machine polishing process. If using by hand or in very cold temps you should Eraser the vehicle before coating.
6 - So, if this has Sio2 quartz protection inside it why are you guys telling me to top it with Reload or CQuartz?
Great question! The protection is there as we stated BUT the contact angle of the water beads and the dirt repellency is not very good / not on par with Reload or CQuartz.
7 - Is CarPro Essence super easy to use?
Yes, usually extremely easy! It is but there are always other variables. As always there can be a little learning curve on some paints. IF you run into a paint where it seems to stick a bit then you need to change your pad type and or your machine speed, arm speed, or pressure.
On very soft paints especially (because it sticks to soft paint easier) consider the following method:
Use a microfiber pad
Spread super fast on speed 1
Raise speed to about 3-4 depending on machine
Using minimal pressure (about a pound or so + weight of machine) use VERY slow arm movement across the section and go only one single pass.
Finally for some paints, consider faster arm movement with half bites into the section, backing up, and then moving forward to avoid any sticking of product.
8 - What if I leave a spot that seems like the Essence stuck to it?
Simply apply a dot of Essence on the area, run over it with fast arm speed, and immediately wipe off the residue. It may simply wipe off with a suede and a dot of Essence as well.
9 - When should I wipe off the residue?
On some paints you could actually leave it there an hour and it is still super easy to wipe off. On soft or porous paints we recommend wiping off immediately after each section.
10 - What about my pads… Do I need to clean them after use to avoid them becoming “crispy” with Sio2?
Yes, clean your pads very well with APC/water after use. During use it doesn’t harden due to the repeated saturation of more Essence on the pad.
11 - What about my microfiber wiping towels?
Yes, wash your towels well or soak them after use if you can’t place them in the washer soon after.
12 - So what are the biggest benefits to using CarPro Essence?
There are a LOT of applications and benefits where Essence excels beyond anything previously available.
Gloss on another level
Hours saved per vehicle
Ease of finishing even the most difficult paints
Thickening of the coating (Essence builds a glossy and reflective quartz coat) which bonds with the paint and merges with CQuartz or Reload if we apply it after Essence.
PPF… We all know its not the best looking means of protection… so this was a really cool find… ppf and clear bras LOVE CarPro Essence! The clarity and gloss of ppf is VERY visibly enhanced when Essence is used on top.
13 - How much cut is in Essence? How large are the abrasives?
Essence uses the same abrasives from Reflect but less of them. However, due to the viscosity and balance of a number of other ingredients we do see an unexpected amount of cut on some paints (especially when paired with a Megs microfiber cutting pad)
14 - How does this work? Is this some kind of marketing nonsense?
No, thanks for your patience as we launched this! Answers to any questions will be answered in this thread. Feel free to post any others you have!
15 - Can I use CarPro Essence without compounding first?
That depends… Certainly you can and certainly it will produce excellent gloss. As for durability this would be theoretically ill-advised. On many paints it will also cut FAR more than you can imagine in concert with a Meguiars microfiber cutting pad. As far as how durable it will be and what your goal is you should compound first to remove oxidation and scratches.
In other words if the paint is not in good condition or is oxidized and you want to have long term protection then you SHOULD compound first.
As for the finish and deeper swirls… that is what test sections are for – when choosing if Essence provides the cut you desire.
16 - What about Essence topped with CarPro Hydro2? Or Hydrofoam?!
Yes, in this case I would advise that you wait until the vehicles next visit or anytime after 5 days to apply Hydro2 or wash with Hydrofoam. In my experience using Essence and then maintaining with CarPro Hydrofoam = Magic
17 - How long until it can get wet?
1 hour before you should allow release into water. BUT remember we are applying Reload or CQuartz over the top so if CQuartz is the choice for topping then CQuartz will still need its cure time to avoid water spots.
18 - If my car already is in good condition... recent decon, polishing, and now has wax on it can I simply use Essence? Or do I need to strip the existing protection first?
This I'm not sure... A little too many variables - with some wax, sealants, and the right pad and pad cleaning etc it would be fine BUT I wouldn't risk it. I would kill the wax off well with strong iron X Snow soap cleaning, then proceed. We may update this after we have enough field testing to prove otherwise.
19 - What is the shelf life expectancy?
1 Year
20 - Should I strip existing protection if paint is in great shape to apply Essence?
Yes, I would strip the wax or sealant as a minimum prep step.
21 - How much should I apply? like a polish... or sparingly like a coating?
More like a polish. For using the CarPro Gloss pad we apply sparingly for most paints. With Microfiber Pad we use more.
22 - How far will the 5oz bottle go?
2-5 cars depending on the goal, the paint, the pad, and more
23 - Can Essence be used as sort of a paint prep product on a well corrected vehicle that already has CQuartz and/or Reload on it, then follow with CQuartz and/or Reload again?
Yes, you can use to "heal" a damaged existing CQuartz coating. Keep in mind that its possible to damage some the existing CQuartz hydrophobic surface when you "heal" any micro marring with Essence but if you are coating again over the top then it should be a moot point. If you are not coating again over the top then you are trading - fixing the light marring for a less hydrophobic and dirt repellant surface.
24 - Does this have to be used with CQuartz or Reload or can I use something else as a LSP or do I even need to worry about using a LSP?
We believe you can use a lot of different lsp that work well with this. We haven't tested others products with it so not positive the results but that is our estimate. I would wait a bare minimum of an hour if applying a sealant or wax with high solvent content in it. You might test that further before doing an entire car to see if an hour is enough. I know one of our friends is planning on moving to Essence as their prep for their high grade Carnauba Wax service. After they have tested thoroughly i will try to remember to update here.
Also see Q&A # 3
25 - What color foam pad is recommended for this? I despise MF Pads
Short answer - Scholl Concepts Spider pad (Blue or Honey)
Long answer - This is a tough one to answer (so many variables again)... It will work with any foam pad really BUT depending on the paint you may have more or less luck with different pads. The issue is this "sticking" the product seems to do on some paints (more in certain environments) On a microfiber pad that seems to be a much shorter learning curve to avoid. I personally tested on Meguiars Microfiber pad (both cutting and finishing, CarPro Gloss pads, Orange Buff & Shine, and Scholl Concepts Spider pads (worked well)and a yet to be mentioned pad...
26 - How do I use CarPro Essence?
Please read the instructions on the bottom of the description page of Essence, see our application video on the video tab, and visit our forum
@JoeNextLevelDetail. I watched your Essence youtube vid👍🏽
Glad you liked it, I have to learn how to edit!
But I plan on building my channel with interesting videos like that so make sure you subscribe, when I do more videos I'll post on the forum tho, my next video is going to be all about finishing sealant so keep an eye out for that!
While Essense is an awesome product you might consider adding a layer of Reload to get better beading properties.
If it's true that essence alone has poor sheeting and self cleaning properties, it's a non starter for me as an AIO alternative and should not be considered in that category imo. If any AIO has to be topped imo it's not an AIO. Sheeting is huge in my book. Yuuuuge!
People used klasse AIO for years but I dont remember anyone saying they would use it alone.
The good thing about this car is that ever since I recommended D115 to my friend [about 9 months ago] I honestly don't think he's done a normL bucket wash since.. The main reason I recommended he switch to waterless is because he would talk about washing his car sometimes every 4-5 days. That's too much work, so I'm glad he took my advice and bought the gallon.
Ever since then he's been really happy with it. He's a buddy from work, so I see his car everyday and it looks spotless every single day! He gets a kick out of being able to wipe it down every couple days at least. So beading is actually a non factor for this vehicle, and if it ever rains [it almost never rains here] the D115 on its own should provide adequate beading.
Sounds like you have a plan and I'm not trying to get you to do anymore work but with the addition of Reload the surface will be more slick. Essence on its own is not slick, which can lead to frustration with a ww. I have a test car and have used Essence with and without Reload and I've used D114,ONR,ONRWW and UWW and all perform better on the Reload. I never used D115 and may be if he uses it as much as you say it'll add some slickness and make the ww easier.
Do you think a different sealant help? I can top it, I'm wondering if it's totally dependent on it being Reload.
And yea he uses it frequently, which has me thinking how long it'll even behave like Reload if I were to apply it. My main concern is how long will it behave like Essence, with all the D115 that it'll be subjected to.
I have Powerlock on two panels and its held up fine, maybe my preference for Reload is where I live as it sheets better. I'm sure you have way better weather than I do! You can always just add a sealant later if you want, either way Essence is special for what it is
I've not tried Essence but have heard a few detailers RAVE over this stuff during Detail Fest.
I need to get me some of that!
I'll probably get Reload either ways..
I should have expanded my statement earlier. But I think he will find it easy to keep clean. I found the feel of the essence finish not super smooth. Once it was reloaded it looked just as awesome just slicker.
Anything that is slick without essence is slick with it.
Any update?
I haven't polished his car with Essence yet. I tested it + Reload on my car 8 days ago. And this past weekend I decided to wash my car... Here's what happened.
Ok so we had a couple of days of light rain during the week, beading was good through the rain.. When I began my wash on Saturday the beading during the initial rinse was also good, not stellar, but certainly respectable..
But then after what was a normL, lightly agitated bucket wash with Megs D111 Shampoo Plus @1:128 this is what it looked like...
Essence + Reload, 1 week after application.
I was shocked. Needless to say, I'm disappointed... There's actually water sitting on the hood in this pic. It took about a minute for it to Finally sheet...
There's water sitting on the hood in this pic as well...
The whole car lost its beading after the most gentle wash ever...
I swear, sometimes I feel like I have the worst luck.😒My car is among the least cooperative cars on earth, this isn't the 1st product that's completely failed to work on my car. Everything from wheel coatings, to tire coatings, certain sealants, you name it, it's failed to work on my car. Lol. And now this...
I was so disappointed that I didn't even post about it. I'm holding out hope that it was somehow a fluke, and I re applied Reload to the whole car.
My wash mitts & drying towels had just been washed the night before with 3D Towel Kleen.. The Only thing I can think of is that I washed my glass towel [used with D120] in the same load. [I normally wash my 6 mitts, 5 waffle weaves, and my glass waffle weave in the same load]
But even then, the Towel Kleen does a great job of washing, and I've never had a problem before. Plus the only thing that came in contact with the paint were the wash mitts..
I dunno what to make of it, but I'm giving it another shot. Next time I'm going to use a Brand new wash mitt.
I'm giving Reload a reload.. It better not fail me twice.
I wonder if you are seeing the effects of the conditioners in D111.
