Question about paint sealant after polish step
J S Machine
Member
I've got the Wolfang swirl remover combo coming for my car which has the SWR and the 3.0 finishing glaze. I will be using the PCXP as well.
My question is in regards to applying the Klasse sealant glaze. When I get through doing the polish step, should I clean the surface in any way before applying the sealant?
It just seems like there might be some sort of polish residue left over from the polish step that might interfere with the adhesion of the sealant.
You are correct, the surface does need to be wiped down. People use IPA dilutions to remove residue or Eraser by CarPro is a good one.
I use a 70/30 IPA (alcohol) wipe down after polishing and prior to applying the LSP.
