Question for you Hot Water Carpet Extractor Owners-
ShineTimeDetail
What are some tricks to getting the most out of your extractor? What are the best procedures for using it also?
Also when filling the clean tank do you put a cleaner in with it? I have yet to put any cleaner in with the water because I don't want to have to deal with clogging the sprayer. Will I clog the nozzle if I add my cleaner to the water?
For my Mytee Hp60 I never put soap in. Only Pre soak stains and agitate if needed but the hot water will do most of the work.
And for cleaning I just suck out the hot water from the clean water tank.
Here's a couple tips...1 use a defoamer in waste tank
...2 keep both solution and recovery tanks clean
...3 If you you use a powdered detergent(not Tide)disolve it with hot
water
...4 Use separate buckets to fill and empty machine to avoid adding
soil to solution tank
...5 Do regular maintenance(cleaning/lube pump parts,check fittings etc.
...6 Read owners manual
I only add an ounce of white vinegar to my clean water tank. Keeps the lines clean and prevents the carpet from drying with a crusty feel.
I use mine like this:
- After a good vacuum
- Pre-spray the area you are gonna clean. [ a descent cleaner, I use Simplegreen All purpouse cleaner a 4 to 1 dilution
for heavy soil, I use help from a stronger cleaner
- I always agitate with a hand brush / helps a lot
- on my Portable / I only use water. I don't put any chemical or cleaner into the tank. except some time's like for Residential Carpet cleaning, that I use, All fabric Rinse for Carpet & Upholstery cleaning
For Auto detail / just clean water
The time you give after the pre-spray is one of the cleaning keys
give at least 5 to 7minutes, for the chemical to work
if you don't give some time to work / your result won't be the same
Powdered detergent?
I don't think Powdered Detergent should be used. Way to strong, a lot of SUDS / Way to much residue on your seats or carpet.
There is Powered Detergent in Pro / Carpet Cleaning Industry, but is not the same type.
I do besides the Auto Detail / Carpet & Upholstery Cleaning, and at least for Car interior, I recommend a All purpouse cleaner / rather than powered Detergent
This is my Personal Recommendation
All are very good recommendations! I like to add RO/DI water in my tank this way there is no build up of calcium.
I get pretty crazy with the care of my extractor to the point that I apply plastic conditioner to make the exterior plastic last and shine lol.
I always use a Malco product called Xtrax. It's a cleaner, de-foamer, and deodorizer all in one. I buy it in 5 gal. jugs, and it gets diluted through my dispenser system. It lasts FOREVER. Literally I'll use the concentrated 5 gal for a year. They also sell smaller amounts. The 1 gal will get you a long ways. You can just add a cap full to your tank.
You always want to use some kind of de-foamer at least. It will keep suds from stacking up in your reservoir. If you don't use one...you could cause possible damage.
Liquid fabric cleaner and deodorizer?
