Question on the Meguiar's DA MF System
Spiney
Mr. Phillips I have a few questions on the Meguair's DA MF system. I just watched the video that your in from Detailfest 2011 about the system. I have it and need to correct my 96 SVT Cobra which is black. It scratches very easily, or so it seems to me.
In the video after each step when wiping off the compound they wiped all over the place, not one direction.
Won't this add swirls?
I want my final step to be Ultima Paint Guard Plus sealer. Can I use the Meguiar's polish/wax and still use this sealer?
If not, what should I use?
Do you have any other tips on the Meguair's system before I do this?
Should I wipe down the car with a 20% IPA before applying the UPGP?
Besides swirls and rids there are some etched water spots on my roof. Any tips on removing them?
Do you know the proper speeds for the compound and polish steps using the Gratiots Garage GG6?
I want to get my car prepped for show season. It is garaged all the time. Never sees rain. I think the water spots came from washing it in the sun.
Thanks much for your feedback. I really enjoy your Videos and your teaching on the Speed Channel shows.
Im not Mike but I can help you out. All of the answers are in red and a few questions for you at the bottom. :xyxthumbs:
In the video after each step when wiping off the compound they wiped all over the place, not one direction. Won't this add swirls?
With the proper Microfiber towels thats a soft and plush you would instill swirls back into the paint when removing the compound.
Yes you can. You will be better off got from the D300 compound right to the sealer. The D300 compound finishes down so well it LSP(Last Step Product) ready.
If not, what should I use? Do you have any other tips on the Meguair's system before I do this?
Always keep your pads as clean as possible. The best way of cleaning the pads will be with compressed air. If you don't have compressed air then the next option will be the conditioning brush. With the brush you will have to clean the face of the pad more often and also change out the pad more. The fibers in the pad can become build of with spend product vey fast and the brush doesn't do the best job at removing all the spent product so removing the pad and washing it will be need so you don't rn into the pad failing prematurely.
No you will be fine.
Depending on the level of the seater spot the DA Microfiber system should be able to remove them.
You will want the setting to be at no more than 4800 opms for the compound application. I believe that will be about 3-4 of the GG.
What washing technique are you using? The two bucket method?
What are you washing your car with? (Mitts, soap, brushes ect.)
Do yo grit guards in your buckets?
What are you drying your car with?
All those are important and need to be address as once you finish you car you want the least invasive method to was your car to ensure you do not instill swirls back into you paint but improper washing and drying.
Hi Spiney,
Hope you don't mind but I edited your original post so it wasn't one HUGE block of text to make it easier for others to read and for myself to reply to using the multi-quote option on vBulletin.
For everyone reading this into the future, when posting to a forum, don't type in large blocks of text as it's hard to follow from line to line and most people will simply click away instead of struggling to read the text. Just a friendly tip... Use the [Enter] key to add white space between sentences... :xyxthumbs:
Mr. Phillips I have a few questions on the Meguiar's DA MF system. I just watched the video that your in from Detail Fest 2011 about the system. I have it and need to correct my 96 SVT Cobra which is black. It scratches very easily, or so it seems to me.
Paint hardness or softness is an unknown variable between car makes, models and years. A friend of mine in the auto industry coined a term back around 1990 as clearcoat paint systems became the norm. Here's the term,
Scratch-Sensitive
What it means is although modern clear coat paints are much harder than traditional single stage solvent evaporation pains like lacquers and enamels, they still scratch very easily.
I have an article on this topic here,
The practical differences between single stage paints and a clear coat paints
Here's the deal, because clear coat paints scratch easily, it's up to you to use the best products you can obtain and use the best technique you can muster any time you "touch" the paint. Including when you wash the car or wipe it clean. I cover a lot of tips and techniques for all aspects of paint polishing in my new book...
Detailing How-To Book and Detailing How-To E-book by Mike Phillips
Wish it were more simple but it's not and you can give your thanks and feedback to the paint manufacturers that make the paint and the car manufacturers that use the paint they make.
If a paint system is so soft that it scratches from wiping in circular motions it's going to scratch in any motion you move your hand while holding a microfiber towel.
I use an overlapping, circular motion for every product I wipe off all the way through every step. I think I show this and a TON of other tips and techniques in this somewhat of a sleeper video we made a few years ago...
How to remove shallow RIDS and how to machine
apply both a paint sealant and a finishing wax
[video=youtube_share;3xJH_MGgbLw&hd=1"]How to remove shallow RIDS and how to machine...[/video]​
This how-to video also covers,
  • RIDS - Random Isolated Deeper Scratches
  • Removing watches and any jewelery
  • Using a DA Polisher without the handle
  • Placing cord over shoulder
  • Priming the pad on a DA Polisher
  • Speed settings for removing isolated defects
  • Downward pressure needed for removing isolated defects
  • How to clean a pad on the fly
  • Where and why to mark your backing plate with a black mark
  • Rotating the body of the tool to keep the pad flat to a panel
  • Why to allow the pad to stop spinning before lifting the pad off the paint
  • How to swap backing plates from a 3.5" to a 5"
  • Machine waxing using 5.5" Hydro-Tech Crimson Finishing pads with Menzerna Power Lock
  • The "Kissing the Finish" Technique
  • How to do the Swipe Test to check if a wax or paint sealant is dry
  • How to remove dried paint sealant using a microfiber bonnet on a dry pad on a DA Polisher
  • How to clean a microfiber bonnet on the fly with your fingernails
  • How to apply a paste wax by machine - Souveran Paste Wax
  • How to carefully wipe a WOWO wax off by hand using Microfiber Gloves and plush Microfiber Towels
  • How and why to fold a microfiber towel 4-ways to wipe wax off
  • How to break-open a coat of wax and then creep out to carefully wipe off a coating of wax
  • How to do the "Final Wipe"
Most "manufacturers" of synthetic sealants have their own specific recommendations for how the surface should be prepared before applying their product for maximum adhesion of the "protection ingredients" to the paint.
I just read the label on the product and all it says is to use the product on a clean, dry surface. They do offer a product called Ultima Paint Prep Plus which states it preps the surface for the Paint Guard.
Years ago I coined the term,
Synergistic Chemical Compatibility
The short version of what this means is that if you stay inside a specific brand of product you'll have a greater chance of product compatibility and thus product performance because the same chemist makes all the products and thus knows how to make the second and third step products work better because they made the first step products.
Make sense?
So if you're going to use the Meguiar's MF System, for a secondary wax use something from the Meguiar's line-up.
Do you have any other tips on the Meguiar's system before I do this?
Instead of watching the live broadcast video of the Meguiar's MF System for years ago at Detail Fest watch the version myself, Jason Rose and Mike Pennington made...
[ame=http://www.youtube.com/watch?v=WhJYFLgIjhE&feature=player_embedded]Meguiars Microfiber DA Correction System - YouTube[/video]
Forum consensus would tend and trend to say "Yes". I post my thoughts on the topic in the article I wrote on how to chemically strip paint.
How to Mix IPA for Inspecting Correction Results
You can always try using a more aggressive compound with a rotary buffer. Keep in mind paint is thin. I cover this in my how-to book...
Do you know the proper speeds for the compound and polish steps using the Griot's Garage GG6?
Meguiar's recommend using 4800 OPM with their pads, on the Griot's I don't remember the EXACT speed settings but the BIG PICTURE is to maintain pad rotation without generating excess heat.
I would suggest trying the 3-5 speed setting range.
Consider this for the future...
How to use the CR Spotless Water Deionization Systems
Wash, rinse and go with CR Spotless Water Systems!
[video=youtube_share;xnU2KdJIfrY&hd=1"]Wash, rinse and go with CR Spotless Water...[/video]​
Why thank you very much. Myself and everyone involved here at Autogeek with all the projects we undertake work very hard to create top quality, professional grade material. It's always so easy for people to complain especially when they have nothing to offer themselves. So I really appreciate the positive feedback...
:dblthumb2:
Thank you so much Mr Phillips for a quick and concise reply.
One of my first purchases was your E-Book, I'll refer back to it for updates.
I really do enjoy your informative videos on Two Guys Garage & Dennis Gage's My Classic Car shows.
I was lucky enough to attend a product demonstration of the Meguiar's MF system by a Meg's field rep last summer at an auto body supply distributor. He was great also.
Finally this forum has been a God send. There are so many talented people with years of experience willing to share their knowledge. Thanks again for the reply.
Hey Spiney,
Thank you so much for the kind words and thank you for your business.
Please keep us updated as to your progress...
:dblthumb2:
