Good Afternoon Mike,
I recently have ordered the BlackFire Pro Ceramic Coating, HydroSeal and BF SiO2 spray sealent.
My question is simply for each of these three products, how long do they or are they supposed to last?
And I don't know how long they last. Just being honest. At least not based upon real-world experience. Most of the time I review any product or tool, it's in that moment I'm using it. If I own the car or it's a co-worker's car, then I'll continue to see the car and this can help to monitor longevity. But if the car is a "cool" car that I detail for a friend or customer, I might not see the car or the customer again for some time.
The BIG PICTURE answer for how long anything lasts starts as you mentioned, the prep work performed to enable the product to work or bond or whatever magic is taking place and then next answer or FACTOR to how long anything lasts comes down to how the car is used and how it's washed or touched.
I know the prep work required for each, but what I am getting from your reviews is that for the hydro seal you do not even have to clay bar, and can just wash and apply, correct? But with the others you do of course, right?
Good question. First - I'm not a fan of sealing dirty, contaminated or swirled out paint. There is a market for people NOT like me that just want protection and water beading and I guess these types of products will suit their needs.
Me?
If it's my own car, a car for one of my detailing classes or a customer's car, then I do what it takes to do the job right. For neglected paint this usually involves,
- Washing
- Chemical decontamination
- Mechanical decontamination
- Paint correction work - be it polishing, or compounding followed by polishing.
- Sealing the surface - this could be a wax, a synthetic sealant, or a coating.
- Or skipping the paint correction and sealing steps and simply using an AIO
So that's how I roll. I'm not actually of spray-on, rinse-off, water beading projects. I kind of like the Si02 washers, where the magic potion IS the car wash, but the spray-on products that you rinse off, be they from ANY company or brand, they're really not my style when it comes to car detailing. I get it that there's a lot of people that do like these types of products and I believe it was CarPro that gets credit for starting this category of product and the trend that made them popular.
I write reviews to explain what a product is, when to use it, why to use and how to use it but that doesn't also mean I use or prefer the products for my own detailing style. Kind of like when I wrote a review for the Makita PO5000C. I found the too well-built but I don't use it and if a FLEX 3401 was in the same garage then I wouldn't use the Makita. I'm not a fan of 5mm gear-driven orbital tools. Had Makita introduced an 8mm gear-driven orbital tool then there might have been a different outcome in my preference.
And finally,
With one of my cars, I am getting a professional to put on the Ceramic Pro 9H coating (either 1 or 4 coatings) which is a permanent coating and will protect against bird droppings even if theoretically left on forever.
Here's what I've experienced and shared in the blogosphere over the last 17+ years.
Modern paints, that is clearcoats, which are in the Urethane family of paints - these paints are pretty tough in and of themselves. If a bird dropping is corrosive enough and left on the paint long enough that it will etch the urethane paint, what I've seen is it will etch anything put on the urethane paint.
So I don't know that any brand of coating is going to stop the corrosive action of the acid in bird poop, or at least in some bird's poop and under the worst conditions. We can all hope. We can even pray to the Gods of Coatings, but I'm not sure there's a 100% bullet-proof "anything" when it comes to the birds.
To make this point - here's a real-world experience that I wrote about in 2008. The incident tool place in 2002. What I describe HAPPENED to a car I detailed and was standing by when the bird dropping landed on the paint.
How long does it take for a bird dropping to etch paint?
From
AskTheExterminator.com
Unlike mammals, birds have no bladder because they do not store liquid wastes. Birds pass their urine into a common chamber used for digestive and urinary wastes. This chamber, called the cloaca, also contains reproductive by-products. So, when a bird lets go with a "bomb" it contains white uric acid crystals and a bunch of digestive wastes like insect parts and seeds.
The above is just a portion of the article. Click the link to read the entire experience I shared.
How would the above three products compare to this in terms of longevity and protection?
Not as long. What you're talking about with the Ceramic Pro 9H product is a normal application of a dedicated coating AFTER any paint correction has been performed and then after the paint has been chemically stripped to accept the coating. These other products are
instead products of or
addition-to products for the normal application of a dedicated coating.
Any help would be appreciated before so I know which one to apply.
Normally after you pay big bucks to have a certified detailer install the Ceramic Pro 9h coating to your car's paint you would ask them what they recommend to use for regular maintanece of this coating. My guess is they will recommend a Ceramic Pro product and keep you in the family. I normally tell others to follow this plan of action. Years ago I coined the term,
Synergist Chemical Compatibility
As it applies to "our" detailing world. I'm happy to see other people use the term.
And, naturally, applying your favorite wax on top of any of these whether be it P21s or Pinnacle Sovereign, would that add any value or increase in shine/gloss?
I would say "no".
I would suggest reading more of my articles on this forum about coatings because I have covered this topic a LOT. Now follow me,
IF - IF you're going to pay to have a coating installed or spend that investment doing it yourself, then what you want on the car is the COATING an the characteristics and benefits IT provides. If you put a car wax on a coating you loose the benefits and characteristics of the coating and gain the benefits and characteristics of the wax.
A quality coating, properly installed also creates what I call,
The glassy look.
Waxes and sealants create a lot of GLOSS but in my opinion, a ceramic coating takes the appearance results to a tick higher level and that's the glassy look.
So ask your coating installer what they recommend for products and recommended maintenance.
Thanks in advance,
Haroon
Well I don't know if I helped you but I tried.
I would say thank you for bringing this question to the forum. Know that I ask everyone that sends me questions via e-mail to post them to the forum. The forum is just so much better at sharing
Info - using formatted text
Pictures
Videos
Links
Than e-mail and also Facebook, Twitter, YouTube and Instagram.
I see you posted this today at 06-24-2019, 01:35 PM
I've been in the garage the last few hours packing for my upcoming Roadshow Class in Auburn, Indiana.
Saturday, July 20th and Sunday, July 21st <-- Info and link to sign-up
Kruse Museum
5634 Co Rd 11A
Auburn, IN 46706
Host Website - krusemuseums.org
