rweekley
- Apr 19, 2010
- 111
Well this weekend, I cleaned up my truck. Washed it Megs Gold Class, clayed it with Megs Clay Bar, cleaned paint with Megs Swirl X, flat white LC pad at speed 5 on my GG DA and then used Klasse AIO , CCS green pad at speed 4 on my GG DA.
Now my question/problem was with the Klasse AIO.
- First, I didn't have any Wolfgang Spritzer as was recommended on the pad, so I tried to use Megs Quick Detailer instead. I just didn't feel/see where I was getting that even application of the Klasse AIO on the paint, with the use of the Quick Detailer, so I stopped using it. What is the purpose of using the Wolfgang Spritzer or as I tried using Megs Quick Detailer? To prevent dry buffing? If so, can you use Megs Quick Detailer on pads to prevent dry buffing?
- Is Klasse AIO hard to wipe off? Even with using the Quick Detailer, it just seemed like it was hard to take off. Maybe I shouldn't even say hard, it just needed a little more elbow grease put into it. Just to let you know, I just applied it and then wiped it off, so I didn't let it sit.
- Third questions, with Klasse AIO, do you have to make 4-6 section passes, or do you just use apply it like a wax with just one pass?
