Rrthomas78
- Dec 8, 2017
- 346
I never bought it...thought about it but never pulled the triggerYeah, next flavor-of-the-month.
Sent from my LG-Q710AL using Autogeekonline mobile app
Bead Maker would work for what you want.
Just a clarification: QDs can be used as drying aids, they just don’t leave any real protection added. If you don’t need a product to clean slight dust off or provide a very short-lived shine, then QDs may not be your best purchase choice. I actually have a ton of them and believe they give nicer short-lived shine than WW or RW QD dilutions, but that’s a very small gain even if my belief is true and I understand why they are discussed as outdated.
Spray waxes meant for drying aids will give that extra shine which will last much longer (weeks/months sometimes) and provide that extra sacrificial layer to likely increase your overall LSP longevity.
Note that your LSP may very likely never exhibit the exact same behaviors as it did prior to the spray wax, as many believe the topper spray mixes with the base coat in some capacity... but likely not something you will notice as a detriment unless you’re really, really trying to see the base coat behavior due to love for it. For the time after the spray wax is applied and still strong, the water behavior and look may significantly change. The top layer usually displays the behaviors until it wears off.
Either way, spray waxes look great and it’s typically a pleasure to have them on top.
Thank for that info on mixing. This was something that in my mind wasn't really making sense. Like using spray wax it's gonna mix with my Collinite. Just hope it won't cause negatives to it.
Reading your post I agree, a spray wax type thing might be better. Top 2 picks are CG V07 or P&S beadmaker. I realize having wax on door jamb paint ain't a bad idea either and I'm sure it can wipe of dust or something from the jams fine?
Wash or use waterless before wiping down jams. Spray waxes usually have no surfactants to clean/encapsulate the dirt so you’ll be causing marring
Right onOk then I'll grab the V07 that way it works as a AIO and don't need to buy more products! Thanks everyone who chimed in!
If I was to pick one(that I have used) for simple and semi durable it would be Opti-seal.
But since then I have swayed to ECH20/Reload for a pretty dazzling look and Sonax BSD for durability.
Nothing that I have used is as easy as Opti-seal, not even Hyper-seal.
But for starts you will have to let this thread run to get some more ideas.
How are you using the Ech20/Reload combo with the BSD? Id assume you're alternating them?
Why do you prefer BSD over the mix on each vehicle respectivelyI am sorry that wasn't very clear. One or the other I guess.
My garage car has the ECH20/Reload and the daily gets the BSD.
Yesterday when drying I primed the towel with PNS and BSD.
Here is a quick chart to differentiate all off the products:
Waterless wash (ex. Ech2O) has high lubricity, low gloss enhancement and low protection
Quick detailers (ex. Last Touch) has medium lubricity, high gloss enhancement and low protection
Quick waxes (ex. D156) has medium lubricity, high gloss enhancement and low protection
