MrOneEyedBoh
Active member
- Mar 3, 2013
- 1,209
- 3
I have Can Coat Evo set to go on my truck here soon, but I had some questions.
Any other pointers on this? Thanks!
- Whats the general temperature application zone(s)?
- I plan on washing it & polishing it in one day and then that following morning - hitting it with prep and then applying the Can coat. How long does it truly take to setup/dry? Should I do multiple passes with Prep, or just one nice heavy soaking/wiping?
- I know it says to not apply in the sun, assuming that is so the solvent doesnt flash fast. But can it get hit by the sun as the day goes on? ( after its applied? )
- I have Gyeon Cure to use in case of rain, but Im more concerned with that morning dew that sets up on panels over night. Should I use Cure if no rain and to prevent the dew from messing it up? Im sure cure hinders crosslinking or something a little bit... no?
- I think I read that I should have a bunch of short pile MFs on hand to keep rotating to eliminate the over saturated towel issues, true?
