The Guz
- Jun 17, 2013
- 8,782
- 60
Stupid question but I also live near you Guz and what does our pollen look like? I have a fresh dark redish dust all over after a day of siting. 3 days. Forgetaboutit!
It’s yellow in my area.
Ok I just got Cancoat and tried it for the 1st time on a customers vehicle… But lets say he were to not pick it up for another day or 2. Does that mean I can’t give it a last minute quick detail wipedown? I just noticed it says no washing for a week?
I just finished using Cancoat Evo for the 3rd time. I like its results on the paint so far. Applications a breeze. Water behavior isn’t as thrilling as I expected but at least it’s definitely there, which can’t be said for the recent “ceramic sealant” I bought not too long ago.
So far 2 of the sprayers are clogged, and I’m taking the 3rd one more serious this time as I don’t want to be left without any of their sprayers by my own fault… But that’s not a problem.
What is a problem however, 1. No tamper proof seal. Already mentioned that though.
2. And I’m starting to think this may be a legit big deal, I’m kinda shocked that Gyeon doesn’t put a clear warning on the box about wearing PPE when using this stuff. Looking at the bottle just now, I think it mentions something in fine print, but I honestly can’t even read it right now, and I consider myself to have pretty good eyesight. Has anyone else felt this way after using this stuff? Or am I overthinking a bit?
I use an eyedropper for 2 reasons. So I don’t have to worry about clogged sprayers and less product vapors in air from spraying.
I wear nitrile gloves while using cancoat or any glass bottle ceramic coating. Never had any issues with product on skin.The simple vapors from trying to clear the sprayer out with water in the backyard is what got me. Not to mention after I was done and washed my hands at least twice, I had a spot on my hand that felt just like dried Crazy Glue on me.
Cancoat contains napatha, so yeah in a very confined or indoor space with little ventilation the vapors may be a bit strong for some
How does applying Can Coat with a larger/rectangular microfiber ceramic applicator compare to applying it with a regular mf cloth?
I’ll be wearing a proper mask from now on anytime I use it. Not 1 of those weak ones, but a proper hard shell mask without a ventilation hole. I’ve never understood how those N95 masks are highly recommended. I used to work in a place where we’d have to handle tubs of ground spices and herbs. If you tried to work around a several hundred pound tub of black pepper without a mask you’d be coughing and have trouble breathing in no time. Those masks with a ventilation hole are absolutely useless. But if you wear a solid mask without a ventilation hole it blocks
100% and you can’t smell a thing.
I've had to spec out a few respirators in my day, when you say "ventilation hole" are you talking about an exhalation valve? And if by "hard shell" you mean a respirator with replaceable cartridges, those all have exhalation valves, AFAIK. The appeal of an N95 mask is that you can throw them away when they get dirty/sweaty etc., as opposed to a respirator where you have to clean the rubber parts periodically. Also, you can't get the kind of organic vapor protection from a disposable mask that you get from a respirator with the right cartridges.
So if you were breathing atomized droplets from the Cancoat, then an N95 would probably stop them (95% of them anyway), but if you are bothered by solvent fumes you need an organic vapor cartridge respirator, that has charcoal filters to absorb the solvent vapors. BTW, I would almost always get the N95 masks with the exhalation valve, it keeps it from getting wet inside if you wear if for a long time, thus being harder to breathe through, and reduces fogging if you wear glasses.
I think 3M or North used to make an N95 that had a charcoal layer, but I haven't looked into any of that stuff since before the pandemic when that stuff went all crazy.
Ok, whatever you are comfortable with, glad you are protecting yourself.
