quick foam gun question
kayi078
have 2 choice in mind now, which one should i get and whats the reason, dont know whats the differences, but i want one which will provide a thick thick foam with DP foam shampoo, also does it needed other tools to connect the garden hose? or just plug and run?
#95QGFMR and the #75QGFMR
this is the 75QGFMR
this is 95QGFMR
which one should i get, any input would be appreciated, thanks
Depending on the price difference, I would go with the first one. Since the fittings are brass, I would imagine that it would last much longer than the other.
is there any other tools this gun require to connect with the hose
such as Brass Quick Connector Set??
everythingautomotive_2033_47811052
I too suggest the higher quality of the 1st one.
Get one from here, none of which have those numbers associated with them, and you will have quality customer service going for you.
If it were me, I would get the quick connect.
is it necessary??? i have a regular garden hose and what makes the foam gun fit the hose??
autogeek foam gun is the same as gilmour foam gun....is there any strong reason that will make me spend $15 more buying in here???
Appears you're new. Most of us have done the shopping around for you.
Buy the Foammaster here from AG--I think you get some free DP with
it. You also are guaranteed to get all the proper connectors.
If you've been reading the posts, you'll notice that you can't put a
price on customer service, and AG is the best.
Old but Wise Guy
I have both and they both work the same . The plastic unit has the advantage of not having that little brass inlet screw that likes to backout if you don't put a little loctite on it.But other than that to me they both will last for a long time
Old but Wise Guy
i am buying the 128oz dp foam shamphoo in here but the foam gun autogeek is selling does not contain any connectors right?? i still have a question not yet solved, foam gun plug in the hose and play?? or do i need other special connectors?? ( using extra money )
I just got the first one for Christmas and the all brass construction is the way to go...:D
is the foam gun attach the regular garden hose and play
Yes, That is exactly how it's done...I haven't had a chance to use mine yet. It's been way to cold. Good luck and have fun...:D
