Quick question about glaze and ipa 50/50.
Lasthope05
So I've been seeing a few people using a glaze and wonder then you guys do an IPA wipedown do you do it before you glaze or after you glaze? I know the IPA is to clean the surface so a wax/sealant will adhere better but when you use it after you glaze will it remove the oils/acrylic in the glaze depending on which product I use?
Is it:
Polish
IPA Wipedown
Glaze
Sealant
or
Polish
Glaze
IPA Wipedown
Sealant
Thanks a bunch,
Alan
The purpose of the glaze is to give you some pop to your finish, by applying IPA after a glaze, you're neglecting the benefits of the glaze, and it may be a necessary step if you intend to apply a sealant. On the other hand, if you're topping it with a carnauba wax, then an IPA wipedown will not be necessary
That said, there are also some polymer based glazes that will provide good bonding to a sealant, which in such case an IPA wipedown will not be necessary...
any wipedown would remove a glaze and thus makes it an unnecessary step. Only use glazes when moving to a carnauba finishing wax.
So you folks that are using carnauba as an LSP, are you not doing an IPA post-polish? I know the main purpose is to promote sealant bonding, but does it also provide any noticeable clarity by cleansing the paint prior to carnauba?
Thanks!!
Thanks for the replies guy. But for an acrylic based glaze such as Danase wet glaze will an IPA also remove that?
So its basically and IPA before any types of glazes right? Oil based glaze would be for carnuaba wax only and acrylic based for a wax or sealant?
-Alan
Thanks!!
Swissvax sells a cleaner fluid to use before applying the wax. So I think you'll see benefits of doing the wipe down before applying a sealant or wax. But another very important purpose of the wipe down is to remove any oils from the polish that could be hiding imperfections. Youll notice that pretty much any polish will hide some imperfections, even if it doesnt have "fillers."
Awesome!! Thanks for clearing that up, Dan!! Sorry for the hijack.
Using an acrylic polymer glaze such as Danase Wet Glaze works outstanding with sealants (and carnaubas too). It is only glazes that are oil based rather than acrylic polymer based that you have to use a carnauba afterwords.
does everybody use the 70% ipa or the 91%ipa?
