Quick Review of CarPro Inside!
Paul@Autogeek
In Addition to Essence, CarPro also introduced a new Leather & Interior Cleaner at Sema
CarPro Inside
Carpro Inside is a multi-purpose interior cleaner with advanced organic cleaners for both gentle and strong cleaning, dilution capabilities, and a mix of surfactants and detergents that promote foaming. CarPro Inside Leather & Interior Cleaner will remove dirt, sweat, built up body oils, dried sunblock and other lotions, and all other manners of interior soiling on all interior surfaces!
Interior Plastics
This car was completely filthy and would have taken hours to clean throughly so I chose to focus on the dirtiest part of the interior plastics to show the cleaning power of Inside. As you can tell this door sill was covered in grime and some sort of sticky substance
Ease Of Use
Inside quickly and effortlessly cleaned up all of the junk on the doorsill with no heavy scrubbing required. 15 Seconds after spraying Inside and the doorsill was transformed into this:
Testing CarPro Inside on Vinyl Seats
Now that I knew Inside had the strength to knock the grime off doorsills I was ready to test it against the passenger seat - which by the looks of it, had not been cleaned in years.
From afar the seats looked alright - but opon close inspection the built-up dirt could easily be seen.
After dividing the seat with some 3m tape I was ready to get to work.
I used a Natural Horse Hair Brush to penetrate the dirt on the seats, and then dried the seats with a microfiber towel
After a quick scrub I wiped the seats dry and was thoroughly impressed with the results.
Close-Up 50/50 Shot
After the 50/50 I went ahead and cleaned up the rest of the seat - Turned out great!
Conclusion?
So how well did Inside perform? Well check out these photos of the Microfiber towel I used on only the passenger side doorsill & seat.
Looks like it cleaned pretty well to me! :props:
how does this compare (on seats if you've tried them on both) to an APC that's diluted to manufacturers specs?
Great review
i will add few more notes:
we supply special foam trigger with the bottle , ( not as the one used here) this to ensure non splashing to areas not wanted.
looks like this :
Inside can be diluted as well, but it will reduce the cleaning power
Inside has nice lemon smell as well after spray.
here is also short video we did to show how its used :
https://www.youtube.com/watch?v=yQSTecpCw-E
How does it work on carpets?
Almost same as going on leather, spray well over the carpets , agitate or brush deep into the fabrics to release all the dirt possible, use wet vacuum cleaner to pull out all, or pressure washer to clean all and let dry.
I'm sure it's a good product, but I'm trying to see how this will sway me away from OPC.
