Quik tip: Long lasting acid resistant sprayer
Eldorado2k
If you're like me, you've tried using chemical resistant and even acid resistant sprayers only to have them fail rather quickly...
If you're looking for an acid resistant sprayer that stands the test of time, this is all you need.
Simply use your tiger grip to remove the sprayer from the consumer bottle, and put it on your bottle of Wheel Brightener [or other acid based cleaner]
Now you'll have a sprayer that'll easily last a year or more... It's no surprise that the most resistant sprayer of all would be on the consumer bottle, because if it wasn't they'd have to refund too many due to faulty sprayers.
Sent from my iPhone
Great point thanks. As far as sprayer for my WB, the one I have is going on 5 years. After every use I remove it and put it in a crap water bottle and spray until the WB is cleaned out , its worth the extra 2minutes.
You don't have to do that with this sprayer. Leave it on 24/7/365. Doesn't go bad.
Sent from my iPhone
Just started doing this with my D140 sprayer. I rarely use WB, but the sprayer is at least 4-6 months old and is a cheapo Tolco white sprayer.
Thanks for the info!!!
I have a few of these around. I need to try them with my citrus solvent mix, that stuff kills my sprayers.
Try it, I think you'll be pleasantly surprised.
Sent from my iPhone
is it just this hot rims trigger sprayer from Meg's or are you saying any other consumer shelf product's sprayer works?
Just this 1. Or any other 1 which holds an acidic cleaner, i.e. Eagle 1 Chrome & Wire Cleaner should work just as fine too.
Wonder if Meg's uses the same sprayer on all of their OTC products? I have a bottle of Natural Shine thats almost empty....
