yep, all I use on my tires is OPC 7:1 to clean and then apply Optimum protectant plus on my tires. I like that it looks complete matte and that it doesn't collect dust or change the appearance of the tires. It provides a completely even finish that makes makes my truck tires look "healthy" and "natural". I used to use hyper dressing 4:1 but even that gave them too much of a dressed appearance in my opinion and wasn't as dry to the touch
Tuff shine is the best I have used.
I personally struggle with finding a tire cleaner that will clean the Yoko tires on the wifes van to 100% black. This includes Tuff Shine, Megs APC, Mothers, Eagle One, etc. I'm tired of wasting money and am using Purple Power for a few dollars for economical purposes because it does the same job as the name brand cleaners.
Now this issue could be caused by the formulation of this particular Yoko tire and its UV inhibitors (as suggested by others) that is causing the permanent browning. Once the dirt and grime have been completely cleansed from the top layer, I'm left with this every time...
Mind you, this is after at least 10 passes of Megs APC... (tire is wet with WATER)
That is burt on dried out Silicone "spray on" tire dressing the more you add the worse it will get. OMG those are way too shiny.
I have had the same problem with YOKO tires before.
To clean all that burnt crap off grab a gal of lacquer thinner and start wiping them down to you bet back to the black rubber again. No Lacquer Thinning will not hurt the rubber or make it soft since you are not soaking the tire in a tub of it. You are just using it to remove all that burn on silicone dressing.
When you are done you can coat them with Gyeon Tire and have nice dark black tires again without silicone.
1 bottle of Gyeon tire will last you years because a little goes a long way.
Forget towels... Can't it be used like a regular tire cleaner? Scrub & rinse?
No per mothers it's not to be used that way. It doesn't work. It doesn't leave anything behind you spray, let it dwell then wipe with towels dress after to avoid blooming etc.
•Between these two products:Will acetone act like the lacquer thinner?
McKee's. I haven't used Tuf Shine. The McKee's works great. Spray it on and watch the brown start running off the tire. This stuff not only works fast and cleans great but also helps the condition of the rubber.
