Recommend me a new product line to use
zacreth
Similar to another thread that was started but I wanted a little more in depth response to exactly what I need instead of an open question on several topics.
I have a flex 3401 and love it. It's the only machine I have even though I should have purchased a rupes 3" but it's okay I mainly use 5" foam pads on it for everything since I have more control.
I'm familiar with Menzerna and have used the line of compounds and polishes for a while but I ran out and need to buy more. So I'm curious, mainly I'm working with softer paints instead of the harder paints that I have been working on so I'm looking to try something new and exciting. What brand would you recommend me to try that has compounds and polishes? Cost isn't really the factor since i want a quality product that provides a high end result to that almost perfect finish. I am topping the cars with cquartz since I apparently couldn't make my mine up but want that deep gloss on black and red Lexus cars.
The cars are personal cars so I want to take my time and get the finish almost perfect and then seal it. The black car has wear so it will need to be compounded but the red is newer and mostly needs a good polisher and finish.
Thanks,
Curtis
You arent going to go wrong buying any of the compound and polishes on AG and Autopia. They dont sell crap. Its really a matter of personal choice.
Griots BOSS Fast, Correcting and Finishing creams. Awesome stuff
I get killer results on most Asian paints with HD one plus an HDO blue pad. It’s a great one step that finishes out pretty darn good
I’m gonna throw out Optimum Hyperpolish. It’s incredibly versatile (can correct or finish depending on pad used), has basically unlimited working time, doesn’t dust, and finishes great (on a polishing pad). It’s very good stuff.
If you need more, Sonax CutMax is just crazy effective with a MF pad, but you would need to follow with polish after compounding on dark colors.
Love to see some impressions on the sonax stuff, so I will selfishly suggest that.
3D is at the top or near the top as far as abrasive technology is concerned. Their ACA line is simply fantastic and 3D One is one of the best if not the best "one step" available on the market currently.
Honorable mention goes to pretty much everything else brought up in this thread. I haven't tried every single one, but from my personal experience Autogeek doesn't carry any junk abrasives.
Thanks for the recommendations so far.... The hyperpolish has me interested and I might pick some of that up to try. I was hoping for more responses so I can try something many people use but I might have to pick and choose and see how i like the results.
I use the PBMG polishes. I’ll arbitrarily pick Pinnacle as my favorite. Advanced Compound, Advanced Swirl Remover and Advanced Finishing Polish. They’re all really good and I’ve been using mostly the Pinnacle over the last 2 years. They haven’t been mentioned, possibly due to price... but being that they are house brand, they come on sale quite often (can’t go wrong with Wolfgang either) and I got my stash of these for bargains at one point or another.
To sum up my thoughts, I often look at my paint when finished and can’t picture it looking any better.
Every product mentioned will work well. It all comes down to your skill level.
Okay after doing some more research I think I'm going to try some Sonax but in the compound section there's several bottles....
(Cut/Gloss Rating from Sonax)
Cut Finish - 5/5
CutMax - 5/3
EX 04-06 - 4/6
ExCut 05-05 - 5/5
Then in polishes there's the following...
Profiline Final - 1/6 Not valid since there's a sealer in the bottle ....
NP 03-06 - 3/6
Perfect Finish - 4/6
Wanting to keep down to at least bare minimum of bottles which compound and which polish? Do you guys recommend? One compound and one polish to finish with the cquartz finish?
What's the condition of the paint you are applying to, I. E. Scratches , hazing, etc? Is it hard/soft? Are you looking to do a 2 step for sure?
First post outlines the cars being used since they are family cars. Both are Lexus and there's one Honda. Black Lexus is pretty severe since he does nothing but go to automatic car washes so it's pretty bad and needs help. The wife's is a deep red metallic with light swirls but there's one area I need to do a scratch repair that will require wet sanding but the rest is great.
I'm used to doing a two or sometimes three step since I normally use Mezerna products. Just wanting to try out new products that work well and Sonax seems like it's worth a try.
I'd go cutmax and the np 3/6 and just adjust pads accordingly. I can't imagine there much those two wouldn't handle.
Sounds good supercarsean. Have you worked with them in the past and if so what pads would you start with normally? I have LC ccs pads and normally start with a white pad to see the results and don't usually need to go to a orange or yellow and for final step a black pad.
I have used the cutmax before. And while I can argue with starting soft and working backwards, my suspicion is you'd probably land at LC orange, which is exactly what I ended up using. If you've used Fg400 it'll likely be similar pad choice. Good luck, make sure to report back!
Nothing but good things to say about cut and finish! Easy wipe off, long work time, little to no dusting, and it finishes really well. I've used it as a one step on black honda paint with no hazing, even using an orange lake country pad. It's diminishing abrasive if I'm not mistaken so make sure to work it long enough to allow it to break down and refine the finish. Only nitpick is that is doesn't have quite enough bite if you're working on hard german paint (ex: audi) that's really hammered.
Cut Finish - 5/5
CutMax - 5/3
EX 04-06 - 4/6
ExCut 05-05 - 5/5
NP 03-06 - 3/6
(Perfect Finish - 4/6) Not valid since there's a sealer in the bottle ....
Sonax Perfect Finish does not contain any wax or sealant. It is a medium cut polish and a very good one at that.
I am a big fan of Blackfire One Step. I've used it on my silver Lexus and my wife's black Taurus that was unbelievably scratched, I was amazed at the end result. So amazed, I saw no reason to try anything else.
