The Meguiar's maroon cutting pad on my PC and Meguiar's Ultimate Compound "got-r-done". I had no marring that I could see, but I still followed up with a polishing pad and Ultimate Polish. Then a coat of Ultimate Wax.
I'm not quite sure of what caused the minor paint problem but this procedure worked in fixing it. A couple of things. The body shop had already sanded the hood with Trizact 3000 (but not aggressively) and then buffed the hood with a light polish. That took care of part of the problem.
If I were to do this again, I'd do a little more work with Trizact 3000 or Unigrit 3000. (I don't know which is the better product, but I have used the Unigrit paper before.) I'd also break out my rotary buffer even though I haven't had a reason to use it for over five years and am a bit out practice. I had to use the PC in a darn aggressive manner to get the results I wanted.
I could probably do a bit more correction, but I remember some advice given a long time ago by the guy who ran Meguiar's Online at the time :xyxthumbs: ..... "Sometimes it's a good idea to quit when the results look 'good enough'."
Thanks for the suggestions.
Tom![]()
Thats interesting, the maroon cutting pad left no hazing or marring after? Thats crazy. That pad isnt recommended for use with a DA per Megs. How hard is your paint?
Well, you know Mike always discouraged the use of that maroon pad back when he worked for Meguiar's...or do you have one of the new 2.0 pads?
I think Mike was a little conservative about those pads when he worked at Meg's.
Mike Phillips said:NOTE: The official recommendation for this new cutting pad is for use with a rotary buffer only. That said we know that a lot of people will use this with a dual action polisher and in most cases if you keep your speeds at or below the 5.0 speed setting it can be an effective cutting pad in addition to your choice of compound, paint cleaner, cleaner/polish or cleaner/wax.
If you choose to use this new cutting pad with a dual action polisher please do a test spot first with your products of choice and inspect the results to make sure you're getting the results you're looking for and if not then stop your process until you can dial in a process that does produce the results you're looking for.
There are many pant systems on the market both OEM and Refinishing, (Auto Body Shops), and each paint system can react differently to different levels of aggressiveness when it comes to pad and product selection. In some cases a cutting pad will remove the defects faster and more effectively but in order to create an acceptable finish you may have to do a second cleaning/polishing step using a less aggressive pad and product before going to wax.
So always perform a test spot first and dial in an acceptable process for your car's paint system before going over the entire car.
PLEASE REMEMBER: When you use a "foam cutting pad" on a D/A, you certainly increase the defect removal BUT you also increase the risk of hazing or micro marring on certain finishes. Both defect removal ability and hazing/micro marring depends on the paint, the user, and the product. Unfortunately, there is no absolute in this arena.
I agree.:iagree: There's so many coming out that sometimes I think it's the exact same product released in different brand bottles.I've seen more new products introduced in the last few years than in all my life in this industry...
I performed a correction like this not too long ago...
http://www.autogeekonline.net/forum/show-n-shine/63097-dodge-avenger-sand-buff-after-bodyshop.html
