Try APC on a rag, if that don't work, try APC on a Magic Eraser. Be very gentle with the Magic Eraser
If neither of these options work, its permanent
I assume that APC is all purpose cleaner? Any preferred brand?
Somebody told me to try lighter fluid (naphtha)?
ISomebody told me to try lighter fluid (naphtha)?
Same issue on mine, 335i....let mthe car.e know if you have any luck for the most part I don't don't ever notice it unread looking down when getting in
I recently purchased a used car that has some scuffing on the plastic trim on the base of the driver's seat. Any sugguestions as to how to remove the scuffs?
Richy are you talking about the red palm applicator?
No. I think the name is high tech cleaning pad. You might find one on eBay. I just looked with no luck. Gianni at DB had some for sale about a month ago.
I have done this before; if nothing works get a matching permanent black magic marker and fill in the scratch. Then take a MF towel and lightly rub the area to blend in. Hope this helps.
You can get matching colors for leather from Magic Mender. Stuff is designed for leather but the color will probably be an excellent match
