Removing Stripes
sullysdetailing
I got a call from on of the perofrmance shops that I detail for, one of the STI race car there are building needs to get the stripes removed. I have removed pin stripe and dealer decals off all my vehicles with out any issue. I removed pinstripes off a n 01 camry one time and it was in an accident and the body shop put a pin strip on top of a pinstripe and with the florida heat it was nearly impossibel to get off.
Now what is the easiest way to get the stripes and glue off the vehicle?
Eraser Wheel
You can find them at most auto body stores for about $15.
if it's the sticker type a heat gun or sun and some typr of adhesive remover.
I use some stuff called prosol, I get it from a local detail shop but ive used it to remove the adhesive left over from lettering on several E250 work vans. This stuff takes it right off
Pressure washer rated at about 6,000 PSI...?
Kidding! I have watched a pro body man use the eraser wheel to get some nasty stuff off before, my vote goes there.
DLB
