AutowerxDetailing
- Apr 10, 2012
- 2,791
Re: Removing swirls left speckles?
I am not a scientist, but I've read a lot on the internet...
What I know to be true:
You are using M83 which is a diminishing abrasive technology (DAT) compound. You are using this with a dual action (DA) polisher and a heavy cutting pad.
My hypothesis of what is happening to your paint:
Possibly, you aren't working the M83 long enough for it to completely break down which is leaving larger abrasive particles that are still being worked on your last section passes. If you are lightening up your pressure on your last pass, without having fully broken down the diminishing abrasives from the compound, the uneven pressure on the pad caused by the "jiggling" motion of a DA polisher will create high/low pressure points on the surface of the pad. These "high pressure points" will cause the abrasives to cut into the paint harder than the rest of the abrasives causing these small tick marks you are seeing.
To test this theory you could try again using constant pressure on the pad, lightening up only slightly for your final pass with M83. Also, you will want to make sure you are allowing the compounds to fully break down and work M83 until it is almost dry.
You could also try M205 with a rotary, if you have access to one, using low speed (600-1000) and a lighter cutting pad as a finishing step which should not leave these tick marks/speckles that can happen with a DA polisher and DAT polish.
Then again this is all just theory...
