Replacement for Zaino
daved
I have a dark red 2009 Honda Accord. The clear appears very soft. For the last couple years I have used Zaino All in One and Z2 (show car polish). I a very low on both products. I have been happy with Zaino, but waiting for it to haze can take some time-even when applied thin. Both products are easy to apply and wipe off.
I do not have a buffer and have applied Zaino by hand. Does anyone have suggestions for a product to replace the Zaino All in One and/or Z2?
Thanks.
Dave
Thanks.
Dave
In some circles it will probably be said that this would be an impossibility........Nay!! It would be akin to blasphemy! J/K :)
Many excellent AIO's out there, Klasse AIO for one. Topped with Klasse SG and/or Collinite 845 looks mighty fine...and with less fuss and cuss. (Can be applied by Hand)
If you still want an AIO then Duragloss 501 would be an excellent choice with its longevity and inexpensive price.
I'd say that KSG has quite a bit of a learning curve, even compared to Zaino.
OP - Grab some DG501 and DG111, they will make fine subs for ZAIO and Z2 if you are on a budget.
Duragloss #501 as an AIO or #105 as a sealant with light cleaning properties. Finish with Aquawax and I defy you to tell the difference between them and the Z products.
I had some great results with Poli Seal and a white CCS hand applicator!
XMT360 is a great AIO, so is Optimums Poli-seal. Z2Pro has a unique look, Four Star UPP looks more like Z5Pro but slicker.
Thanks for the input. I ordered both Klasse products mentioned above. Is it necessary to strip the Zaino products before using the Klasse products? If so, what product would strip the Zaino?
Thanks.
Dave
Thanks.
Dave
Yes. I would strip the Zaino.
For removal: 50/50 IPA/Water Mix, or PrepSol, one panel at a time.
