Hi all,
I need some help with the interior trim to see how I can improve it to make it less to be seen on these marks. I have been working on my car this afternoon as I have used wet and dry sandpaper 400 grit and then I used 800 grit to rubbed on the area where the scratches was so I have removed most of the scratches so it looks good.
Here is what it was before:
After:
I have been used the plastic cleaner called PlastX to cleaned on the plastic to removed the dirt then I have applied meguiars ultimate black plastic restorer to restore the plastic trim back to the original color. The results have been amazing but there are still some work that I need to work on it for best results.
As you can see there are some marks on it where it can been seen. Do you know how I can improve it to make it less noticeable?
What do I need to use to make it look better?
Thanks in advance.
After:
Thanks in advance.
