swanicyouth
- Mar 3, 2011
- 9,388
I just used Optimum Products to restore the roof rack rails on my 01 Pathfinder. The truck was Opticoated last month, but I removed the roof rack because the rails needed a little TLC because they were kind of faded. They are metal, and have a crinkle black single stage paint finish. I didn't take before pictures, because I didn't expect them to turn out so good. Also, Opticoated the plastic seals around the outside of the windows. First I washed the truck. Then I polished the roof rack rails with Menzerna IP. This was failing, as the IP was staining them white! So, I decided to try some Optimum Finish Polish. This worked much better than the Menzerna. It seemed
that the Optimum polish just had a lot more work time, and it was "oil like"(which was a good thing). Also, it was blue not white, it actually removed the white stains from the Menz polish and left a nice matte black. Then I cleaned them with ONR and IPA. After that, I used some vinyl
wrap to cover up the front of the rails where the paint had just chopped off. It came out really well. Opticoat is great on external plastics and trims because it darkens them and it's permanent. Here are some after pics
All of the after pics are just dried Opticoat with no trim dressing on anything at all.
Also did the external window plastic parts with OC. This is tricky, because it can faintly streak after it sits for a minute, a second very light coat fixes it if applied while the original coat is still tacky
