Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Review: BLACKFIRE Mat Cleaner & Protectant
What it is?
Floor mat cleaner and protectant.
What it does?
Cleans rubber floor mats and cargo liners AND leaves them conditioned and protected.
When to use it?
On an as-needed-basis. If your mats or cargo liners are dirty - then clean them.
Why to use it?
To maintain a clean looking interior.
From the manufacturer
BLACKFIRE Mat Cleaner & Protectant cleans dirt, grime and minor spills while conditioning, preserving and protecting. This product is pH neutral.
My comments...
This is a new category of product in the industry. The most common question I see asked about this category of product is,
Why not use an all purpose cleaner?
The answer is yes, you can use an all purpose cleaner. You can also use a normal car wash soap. The difference is these two types of products only clean. The BLACKFIRE Mat Cleaner & Protectant mat cleaner and protectant goes the extra step of conditioning, preserving and protecting.
My Guinea Pig
2018 Honda HR-V
Step-by-step directions
Step 1: Remove mats from car
Clean on the ground or to make it easier, place on a table.
Step 2: Spray BLACKFIRE Mat Cleaner & Protectant onto the mats and then agitate with a brush.
Step 3: Rinse the mats to remove the cleaner and anything that was on the mats.
Step 4: Flip the mats over and repeat. (optional step)
Step 5: Place the mats in a clean place to dry.
Here's the clean and dry mats the next day.
Step 6: Replace the mats back into the vehicle.
Review
Clean, protected mats add the finishing touch to a clean interior.
This is a very simple and straightforward product and process. The mats were not horribly dirty but looked much cleaner and even like brand new after using the product. I've never used a product of floor mats that goes beyond cleaning so with this product it's doing multiple steps in one action as it also conditions, preserves and protects the rubber surface.
Most people just clean their floor mats and then put them back in the car. It's where your shoes touch down and as such, most people don't give them too much thought or care. That said, people are different and some people really like to be pro-active with the cleaning and preserving of their vehicle, both inside and outside. If this describes you and you think you would like a dedicated mat cleaner and protectant then I recommend you give this product a try.
On Autogeek.com
What it is?
What it does?
When to use it?
Why to use it?
My comments...
My Guinea Pig
2018 Honda HR-V
Review
On Autogeek.com
