The Guz
- Jun 17, 2013
- 8,770
- 46
Thank you Avi for sending this product for review.
Products:
CarProDHydrate Drying Towel
Autogeek carries the 20 x 20 version and not the 28 x 40 version that is in this review.
Cost:
$24.99 for 28 x 40
$15.99 for 20 x 20
Product description:
Specs:
CarPro introduced this drying towel around mid 2018. It is a dual side microfiber drying towel. One side is the plush twist loop microfiber material that is used to dry the painted surfaces. The other side is a flat woven nap that is reserved for drying glass to avoid streaking.
This is the large size at 28 inches x 40 inches. The flat nap side has the newest CarPro logo imprinted on it.
I placed the towel flat on the front glass of my 2002 Camaro to show how large the towel is.
I did not take any other photos so the video will have to show it’s effectiveness of how well it removes water from the surface.
Final thoughts:
I have been using this towel for a few washes and it does a good job. This size towel is enough to dry my 1999 Grand Prix which is a midsize sedan and enough to dry my brothers 2018 Equinox. The dual side serves it purpose. It dries the glass to a streak free finish with one pass. The plush side absorbs water and is soft to not damage the paint while drying. The orange border is suede and it will not damage the paint either.
The material is similar in it being a twist loop like the Griot’s PFM,the Gyeon Silk Dryer and other towels that use a similar design structure.
The included information on the package states that this towel is designed to be dragged on the paint for drying rather than blotting. Well I have done both methods and this towel does both just fine.
One thing I noticed with this towel is unlike the large PFM drying towel,the CarPro towel does not get as heavy yet it does just as good as the PFM. It is a good alternative to the PFM which is good for those not wanting to spend so much on a drying towel.
For larger sized vehicles an additional towel may be needed.
Give the towel a try and report back your feedback.
Products:
Cost:
$24.99 for 28 x 40
$15.99 for 20 x 20
The CarPro Dhydrate Drying Towel will revolutionize your entire car drying process! The ease with which the CarPro Dhydrate Drying Towel can engulf every drop of water on your vehicle will leave you so amazed you may need it to dry the drool off your chin!
TheCarPro Dhydrate Drying Towel was designed to create as little drag as possible to avoid washing swirls and scratches while you are drying.The CarPro Dhydrate Drying Towel will glide effortlessly across the surface of any paint, treated or untreated, coated or uncoated. All without damaging the existing protection that is on your car already.
Dueto the extreme absorbency of the CarPro Dhydrate Drying Towel, drying your paint off could not be any easier. Simply lay the CarPro Dhydrate Drying Towel across the surface you are drying and slowly drag it across. That’s it, you are now ready to move on to the next surface without worrying about any water being left behind to evaporate and cause water spots.
If it isn’t enough that the CarPro Dhydrate Drying Towel is made with materials that will greatly reduce the risk of scratches and swirls,the light grey color of the CarPro Dhydrate Drying Towel makes it incredibly easy to spot any dirt or debris that may gather in it fibers. This means that it would be nearly impossible for you to accidentally drag a debris-riddled towel across your perfect detailedpaint!
If that still isn’t enough for you to feel confident in your paint’s safety while using the CarPro Dhydrate Drying Towel, this towel has even more scratch reducing properties! The CarPro Dhydrate Drying Towel is made with an edge made of microfiber,not piping. This means that the edges won’t cause any scratches during use. Combine that with the fact that it tagless and you would be hard-pressed to find something on this towel that is capable of scratching your precious paint.
The CarPro Dhydrate Drying Towel is durably made and is designed to be completely lint free. Making it extremely easy to clean and ready for use after use without wear!
Specs:
- Size: 28" x 40"
- Blend: 80/20
- Gsm: 540
- Edge: Orange Microfiber
- Color: Grey
- Made in: Korea
Final thoughts:
