CEE DOG
- Jul 12, 2009
- 7,358
Review: DP Gloss Tire Gel (New Formula-Blind Review)
Introduction:
This review is different then most, as we are reviewing not only the new formula of DP but also the new formula of DP with Polycharger added by Old Tiger. To contrast we will also show DP old formula (O) in the review so you can see the side by side improvements of the new formula. What makes this review more exciting then most is it is a partially blind review. The credit for the product and the idea of a blind review goes to Jim (Old Tiger). Thank you Jim! Last week he sent me a sample of DP Tire Gel (New formula) and also sent me a sample of the new formula with polycharger added. Jim did not tell me which is which. He simply marked a line on one of the bottles, which after receiving I labeled as “(A)”. The other I labeled as “(B)”.
Being that this is a blind review I slightly modified the standard structure I use. The “Initial Product Observations”, “Product Description”, etc. will refer to the new Formula of DP Gloss Tire Gel (as currently sold) unless specifically noted.
Initial Product Observations:
1.- Manufacturer Claims: True (Durability testing in progress) (Not tested on interiors)
2.- Packaging: Plastic bottle with a snap up cap
3.- Directions: Simple
4.- Consistency: Just right (thick but not goopy) (thicker then the old formula)
5.- Color: White
6.- Scent: Fresh and Minty
7.- Size: 32 oz.
8.- Current Price: $15.99 (5-10$ cheaper then the old formula)
9.- Price Per oz: $0.50 (based on 32 oz. bottle)
10 – Also Available in: 128 oz.
11.- Manufacturer: Detailers Pride
12.- Made in: USA
Additional products used for prep, during application, or removal:
1.- Amazing Roll Off
2.- Tire Brush
3.- Cobra Tire Swipe
4.- Eagle One tire swipe
Product Description (from AG website):
DP Gloss Tire Gel is a long-lasting rubber dressing and protectant that gives tires a sleek, subtle shine. The durable polymer formula contains powerful UV blockers and ozone protectants to keep tires, wheels wells, and rubber trim looking like new. DP Gloss Tire Gel can be used on any rubber or vinyl surface
Method of Preparation:
I washed the wheels with ARO and allowed to dry.
Method of Application, and noted Observations:
Using separate tire applicators I applied product as follows:
(O) ---- Passenger side front wheel
(A) ---- Passenger side rear wheel
(B) ---- Driver side rear wheel
On the drivers side front wheel I applied all 3 products. Each product was applied to approximately 33% of the tire. I only applied 1 coat of each but you can add more then 1 coat leaving 30 minutes between each coat.
The new formula of DP Tire Gel (A and B) is less glossy and less greasy then the old formula. It went on easily and produced a very nice finish. While (A) and (B) both applied similarly the (A) formula seemed just the tiniest bit thicker. (A) definitely produced a slightly darker finish then (B). It’s slight enough that its not very noticeable on different tires but side by side you will see it. Both look great and did not require much product at all. I think (B) scent is slightly stronger.
The old formula is a little runnier but is also very easy to apply and goes a long way. There is a huge difference in gloss between the old and new formula. However with the old formula the gloss could be controlled. You could keep it glossy or lower the gloss. During application the clouds started rolling in and threatened to derail this review. Not sure what the effect would be of rain on the products without them having 30 minutes to cure… Luckily just a few drops fell on my freshly washed paint… There was no issue for the tire gel review. After maybe 30 minutes or an hour I came back and rubbed my fingers across the applied areas of each product. On (A) and (B) there was nothing on my fingers. On (O) there was definitely product on my finger. For those that would like to see this on video here you go. I used a white paper towel to accentuate the results.
Please see the pictures and rejoin me afterwards to see the listed Pros, Cons, and Summary.
01.- Cleaning
02.- Cleaning
03.- After
04.- After
05.- Products (Note the DP in bottle pictured here is the old formula)
06.- Product A
07.- Product A (zoom 2)
08.- Product A (zoom 3)
09.- Product B
10.- Product B (zoom 2)
11.- Product B (zoom 3)
12.- Product O (Old formula)
13.- Product O (zoom 2) (Old formula)
14.- Product O (zoom 3) (Old formula)
15.- Uh Oh!
16.- Side by Side by Side
17.- A & B (side by side)
18- O & A (side by side)
19- B & O (side by side)
20- That’s where I’m headed next!
21- Luckily this was all the rain we got
22- The Camera woman - blame her
Pros:
1.- Very nice satin finish (Really nice and dry to the touch)
2 – Small amount goes a long way
3.- Versatility (Can be applied to interior vinyl or to rubber trim) Not tested yet
Cons
1.- For those who like really glossy tires you will be missing out
1.- Can’t wait to see Old Tiger fill us in on which one was polycharged!
2.- Durability results to follow over the next 1-2 months. The vehicle that was used is a daily driver for my wife and sees plenty of weather.
3.- I have to try this new DP formula side by side with Opti-Bond. Opti-Bond had become my favorite of the two but I think I like the new DP more. To see some picks of the Opti Bond click here: http://www.autogeekonline.net/forum/product-reviews/24938-review-optimum-opti-bond-tire-gel.html
Final Observations and Summary:
I really like the new DP tire gel! It’s very impressive to me how dry the tires are with a nice finish. As such there shouldn’t be any dirt sticking to them. It seems that while the price went down the product has improved as well. The current price is equal to that of Opti Bond. It should be noted that the old formula of DP can be wiped down 30 minutes after application if you want to lower the level of gloss. I hope you enjoy and I look forward to any comments or criticism. Be sure to thank Jim for providing the product and the idea.
And the product link: DP Gloss Tire Gel penetrates deep below the surface to hydrate and refresh dull, dry rubber.
Introduction:
5.- Color: White
7.- Size: 32 oz.
12.- Made in: USA
2.- Tire Brush
01.- Cleaning
02.- Cleaning
03.- After
04.- After
06.- Product A
09.- Product B
15.- Uh Oh!
Pros:
Cons
