CEE DOG
- Jul 12, 2009
- 7,358
Review: Duragloss Aquawax (#951)
Introduction:
I’ve been using Aquawax since I first stepped foot on AG. AW was on one of my first orders. It is a well-known quality product so I have never done a review or specifically tested certain qualities on it in the past. However, Old Tiger (Jim) contacted me with some different products that he would like to see a detailed review on and this was one of them. Jim also added Polycharger to some Aquawax and sent it to me to test side by side with the regular AW I’ve been using. Thank you Jim!
Product Description (from AG website):
Enhanced gloss and an incredible “wet look”!
Duragloss Aquawax is formulated to wax after washing in one easy step. Duragloss AW produces a high gloss, durable finish with minimal effort. Aquawax contains no abrasives and is clear coat safe.
This is Duragloss’ most popular product! Duragloss Aquawax produces a deep, wet gloss on clean paint. On an already waxed finish, Aquawax deepens the reflection, enhances the shine and increases slickness. This is a synthetic sealant spray with the gloss of a wax.
Since Duragloss Aquawax is a polymer sealant, it has good durability in its own right, but it will last longest when used as a topper.
Initial Product Observations:
1.- Manufacturer Claims: Testing durability
2.- Packaging: Quality black bottle and trigger with typical DG label (I would prefer a finer mist)
3.- Directions: Clear and simple
4.- Consistency: About that of a QD spray
5.- Color: Aqua Blue
6.- Scent: Like a slightly overripe fruit (but good)
7.- Size/Price: #951 - 22 oz. ($8.99)
8.- Size/Price: #952 - 128 oz. ($34.99)
9.- Manufacturer: Duragloss (Brothers Research Corporation)
10.-Made in: North Carolina USA
Products used for prep, during application, or removal: (see picture)
I also used a couple buffing towels and some painters tape not shown in this picture.
Method of Preparation, Application, and noted Observations:
I’ve used Aquawax as a drying aid many times so for this review I thought I would specifically test some particulars of the product and it’s hybrid cousin that Jim created. Before we get to that I did use them both side by side as a drying aid to test Jim’s Polycharged version vs. the standard AW with which I am familiar.
I used my Sky Redline for this test. I was specifically looking for any differences in application. Having found no definitive differences in this regard I next zeroed in on appearance and slickness, which will both be covered in the next test.
This next test would include:
Using AW and AWpc as a spray wax on an already dry panel.
Setup for a durability test of both AW and AWpc.
For this test I started by washing a test panel that’s been sitting in my garage. Apologies in advance for not taking the time to get the paint perfect before this test. It would have been a perfect opportunity to break in my Surbuf pads to get the deep stuff that’s still there.
The panel was just dusty so I sprayed it with water. After letting the water run off I sprayed it down with IPA liberally.
Setting Up
Spraying IPA
IPA Dwelling
After letting it sit a minute I sprayed a bit more and wiped it dry. Next I taped off a couple areas and labeled them for the tests. On the now dry panel I first sprayed AW on its testing area and buffed it off with a buffing towel. Then I applied the AWpc to its section and buffed it off as well.
After Buffing
Aquawax Side (After Buffing)
Aquawax with Polycharger Side (After Buffing)
When applying to this dry panel I noted that the AWpc seamed to streak just a wee bit easier then the AW. The sun had just come out for a few seconds so that could have been the difference. Please note that AW as a drying aid (spray 1 panel at a time and wipe while drying) has never given me a streaking problem. Lets get to the slickness and gloss... Since my subconscious is already tainted with my view of Polycharger I asked my wife to come give me an unbiased opinion and tell me which was most slick.
Video: Slickness Test
As you can see in the video she chose the Polycharged side. While both leave a very slick glossy finish I felt that the Polycharged version was slightly slicker then its natural cousin. As far as appearance I found no discernable difference between the two at the time of the testing. After a few more views at different times of the day in different lighting I tend to want to say the AWpc side is ever so slightly deeper but I couldn’t in good conscience tell you I’m sure of that. Without telling my wife my opinion I asked her the same thing and she leaned the same way while being just as unsure as I.
Does AW and/or AWpc truly dry clear without wiping?
A few months ago I read that Aquawax dries clear, which makes it great to use in hard to reach places. (Apologies to who told me that since I don’t remember) After reading this tip I used it in the barrels of my rims as well as my doorjambs (hinge side) a few times without wiping it down. I did however hit it with my air compressor after applying. What I had read did indeed seem to be true and I never noticed any residue. Today provided an opportunity for me to test this under stricter conditions and without using the air compressor to spread it flat. I sprayed each product one time over their already buffed areas and walked away.
Aquawax Side (1 spray and let sit)
Aquawax Polycharged Side (1 spray and let sit)
Clear Test Area
After a few hours I came back to see how clear it had dried. While there wasn’t any white or colored residue there was most certainly the clear oily buildup of AW and AWpc that had not yet completely dried. Their appeared to be no difference in how one dried over the other. Although it’s not completely dry yet I’m pretty sure it’s not going to clear up much more then that. Forgive the spots in the pictures where you can see I poked at it a bit. Just focus on the drops that are drying…
Aquawax Side (Clear test a few hours later)
Aquawax Polycharged Side (Clear test a few hours later)
Another quality that I have assumed based on what others have told me is that Aquawax does not have much durability. While I don’t plan on using it as a standalone product on my cars I thought it would be a good idea to actually test this (Especially now that I see DG claims a durable finish. With the Polycharged concoction from Jim we have yet another great reason for a durability test. As you can see in the previous paragraphs we are all set up for said durability test. Now we only need time and the elements.
Pros:
1.- Slick and Glossy
2.–Excellent price
3.- Ease of application
4.- Won’t stain trim
5.- Smells nice
Cons:
1.- I’m expecting durability to belong here in the cons section but I’ve never used it on its own so can’t be sure. This is not a stand-alone product based on what I’ve read and seen but I’ve never used it without another product beneath it so I should learn something here. I’ll learn a little more after some rain. Unfortunately it looks like we don’t have any coming this week. We might have to manufacture the elements ourselves J
1.- AW can get streaky but only if you apply too much. This should not be an issue for most. I debated about streaks being in the con section or not but I’ve never had issue with it when drying with it or using it in shade. Until I had a wee bit today I would have put it in the Pros for no streaking. Most spray waxes and QD’s streak if you apply too much or mess with them in the sun.
2.- How long will AW last on its own and how will the Polycharger affect durability?
3.- Raise your hand if you think I should move the test panel away from the pool so chlorine doesn’t influence the test. (Don’t worry I did)
Final Observations and Summary:
The AG description specifically states to use it as a topper so I must assume it lacks in protecting paint from the environment. I couldn’t find any info from Duragloss saying not to use it as a standalone product.
With or without Polycharger this is a terrific synthetic spray “wax” and if you haven’t tried it you should check it out. If you have some Polycharger then give this mix a try as well. I agree with Jim that it makes an already wonderful product even better.
And the Product Links:
22 oz. http://www.autogeek.net/duragloss-aquawax--951.html
128 oz. http://www.autogeek.net/128ozduaqa9.html
Introduction:
Setting Up
Spraying IPA
IPA Dwelling
After Buffing
Clear Test Area
Pros:
2.–Excellent price
5.- Smells nice
Cons:
