Review: GTechniq G1 Clear Vision Smart Glass
brazuca
Product Info (From AutoGeek)
The only glass coating that lasts up to two years! Gtechniq G1 Clear Vision Smart Glass provides a clear, protective coating over glass to keep windshields cleaner and clearer. The coating is resistant to wiper blades and outlasts ordinary glass sealants. Gtechniq G1 Clear Vision Smart Glass improves driver visibility in all weather conditions.
Gtechniq G1 Clear Vision Smart Glass is built on the same nano-active technology as C1 Crystal Lacquer and Gtehniq's other innovative coatings. It bonds with the glass to create a slick barrier between the glass and the elements. Rain beads up and rolls off treated glass. Dirt is less able to stick. Insects and ice are easier to remove.
Gtechniq G1 Clear Vision Smart Glass prevents smears caused by wiper blades and allows them to glide noiselessly over the smooth glass. No matter what the conditions are outside, Gtechniq G1 Clear Vision Smart Glass helps keep your windshield clearer.
Manufacturer application instructions and some (cool) videos
Exterior Coatings // G|Techniq
Do not dilute. Apply at a temperature above 5oC and not in direct sunlight. If you are applying indoors ensure that there is adequate ventilation. Ensure that the surface to be coated is entirely free from fats/oils (we recommend cleaning and then polishing the glass with Gtechniq G4 Glass Nano Polish). For application of g1 use the application pad to wipe g1 onto the surface of the glass ensuring complete and thorough coverage. We recommend three coats on windscreens (apply first coat, allow to dry for 10 minutes without buffing and then apply the second coat) and a single coat on side and rear screens. Allow the coating to dry for 15 minutes. Once dried use another lint free cloth to apply the residue remover and then buff using a cotton towel type cloth (cotton is preferable to microfiber as the densely packed fibers of the microfiber cloth may remove too much of the partially cured coating from the surface) until you have removed all residue. We recommend buffing areas no bigger than quarter of a windscreen or half a side window at a time. On application it is recommended to thoroughly clean your wiper blades with IPA or window cleaner or if they are towards the end of their lifecycle to replace since heavily worn or soiled blades can judder on the surface.
Product PDF
http://gtechniq.com/shop/3s-for-car...329808b&fname=g1_Application_instructions.pdf
Presentation
The product comes in two versions, 15ml and 100ml.
Package contents: G1 (glass coating), G2 (residue remover) and some round cotton applicators stored in a zip lock bag
Price
Currently at $17.99 (15ml). I got the 15ml version on july 2012 ($15.99, introductory price i believe) and used a 20% coupon, it was a sweet deal ($12.8 final price).
Review
My car have an all glass roof, so, lots of glass. I was using Menzerna PowerLock on pretty much everything, paint, windshield, windows, headlights, glass roof etc. But i decided it was time to try some glass specific products because i was not liking the durability of the PowerLock, specially on the windshield where the wiper blades runs. PowerLock is a paint product so it's understandable that the bond is not the same on glass. On the side windows, without the rubbing of the wiper blades, the durability is satisfactory so far though.
So, i'm currently evaluating GTechniq G1 ClearVision Smart Glass coating against Menzerna PowerLock sealant on the windshield. I was undecided between G1 and aquapel, but picked G1 because of the 2 year durability claim and because you have to use all the Aquapel once opened/seal broken. My goal was to check if the glass specific product is worth the investment, since i have a quart of Menz Powerlock (and other sealants).
I applied the products on December 22th when I last detailed my car. After the car wash/dry, the windshield was clayed (simoniz glass cleaning purple clay with ONR), dried, and got a IPA like wipe down (SONAX paint prepare).
Products used (forget the brush)
I wish I could polish the windshield with G4 glass polish (as per instructions) or with cerium oxide but I did not have them. Driver's side got 3 coats of G1 (manufacturer recommendation for windshield) and passenger's side got two coats of Menz PowerLock. The application of both products is different, but equally easy. They were applied as per manufacturer instructions.
G1 seems to be really volatile, so keep the container closed all the time.
Use nitrile gloves when applying. I didn't and it was a little harsh with my hands.
Car is non garaged, left outside at the mercy of the elements while i'm at work and garaged at home. Since application, weather here is crazy, lots of sun, lots rain and heavy wiper usage.
Results (so far)
Remainder: Menzerna Powerlock on passenger side and G1 on driver's side.
Hope you can see them in action in this short shaky clip. I can definitely see Menz Powerlock still protecting, specially where the wiper do not rub. But G1 is awesome.
Video (shaky and loud music)
00024 1 new - YouTube
Amount used
I did some marks before and after using the product (half windshield, 3 coats). I believe with the 15ml version one can probably coat a windshield (3 coats), rear window (1 coat) and driver and passenger side windows (1 coat) on a hatchback like mine. Maybe all side windows can be coated, but not sure. I believe i used the correct amount.
Conclusion
Menzerna Powerlock is my go to paint sealant. But on the windshield, where the wiper blades rubs, it was lacking durability. It is good if you apply frequently, with really good water sheeting when freshly applied, but I wanted something longer lasting and with less maintenance needed. After 50 days, the protection is vanishing, it can't withstand wiper rubbing much longer.
The water spots on the Powerlock side are bigger than the ones left on the G1 side (none are etched though).
No wiper noise on both sides.
G1 is going strong. Water sheeting is awesome and no smear so far. The next time i detail my car, I will polish and reapply the G1 on the whole windshield. Time will tell if it really lasts 2 years, but I'm sure I will get solid durability from it.
My test is inconclusive regarding the 2 year protection manufacturer claim and, to be honest, i do not believe it. But the test helped made my mind about an specific glass coating product. Also, i will probably test other glass coating products because G1 is on the expensive side. But now i know i want a G1 like product on my glass roof, windshield and rear window. On the side windows, i will keep using Powerlock, it is fine and cost effective there and i have a full quart bottle here.
If you are undecided and willing to try GTechniq G1, go ahead, it kicks ass and you won't be disappointed. :dblthumb2:
Best regards!!
Trying to embed the video:
[ame=http://www.youtube.com/watch?v=2qCW16V3n88]Gtechniq G1 x Menzerna Powerlock on glass after 55 days - YouTube[/video]
Nice review. Definitely pick up some g4 and polish before you coat the whole windshield to get max durability. I applied g1 back in August to my dd that, like yours, sits out in the elements all day every day. So far, going on 6 months, it still beads and sheets water fantastically, even in the winter salt and snow. Definitely a good product, great review.
I just had a gallon of v7 delivered yesterday. I think ill be using it after weekly/ 2 weekly finish to top everything off.
I got some cerium oxide powder. I will get the Griot glass polishing pads and use that. I think it will do the trick. Good to know its going strong after 6 months, really an awesome product. Thank you! :props:
Very nice review!!! Thanks for sharing. Looks like good stuff.
I have one complaint. I dot understand why you couldn't use gtechniq exo And avoid buying all these other products dedicated to different parts of your vehicles. That being said exo, if applied with two thin layers should last just as long. Why make everything so confusing. I don't want to bombard my garage with more products than I have to:(
EXO wwas released long after G1. I would say you are fine with eXO.
I don't have EXO. And if you read my review, i bought G1 on july 2012. When EXO was released? After that for sure. :xyxthumbs:
Well, after less than 4 months, i have to say, i regret for having used GTechniq G1 on my windshield. At lot of streaks, smear and compromised visibility. How can i remove the rest of it from the windshield? Thank you
I'm glad I found this review before buying. Sorry this did not work out for you, but you just saved me some money!
-Ed
My comment have nothing to do w/ the product you reviewed. However, i used the Gtech C4 permanent Trim Restore Vs. Cquartz Dlux...and i regret using the C4 because it streak my trim pieces while Dlux is awesome.
Snellvilleauto havent seen you on here in months.
Sent from my SGH-T999 using Tapatalk 2
G1 is still the preferred coating on the windshield. This is due to its resistance to wiper-blades.
The best combination is G5 over G1, sheeting as low as 25 mph. :)
You definitely got a bad application, this sounds typical of an application where not all of the residue was removed.
To remove the coating, use a glass polish and a DA
What do you mean by streaking your trim? I have never seen or heard of this before
I used as per instructions and don't think i got a bad application.
Anyway, i bought a glass polish and will try that. Thank you TrKent for the tip. I have some G1 left and maybe will give it another try. If i do, i will update my results.
Best regards
