Review: Gyeon Bug & Grime Remover
kevincwelch
There are parts of the country where bugs are just a real nuisance and a problem for vehicle owners. Chicago is not among them. In 9 years of living in the Chicago area, I can`t recall any significant bug collisions on any of my vehicles that have required anything other than a hose and a good soak with whatever rinseless or 2BW I`m using to remove the stuck-on exploded biologics.
When my wife took the kids on a road trip last summer to New York and came back with a grill full of nasties, I thought I`d get some bug remover for the next time she took a road trip. Well, over the past week, my wife took the kids to Little Rock, Arkansas to visit some friends and relatives, and when she came back a week later, the front end of the Highlander was pretty decently assaulted by insects, and they were splattered just about everywhere.
Now, this is probably minor compared to what a lot of you Southerners experience, but for us here in the Chicagoland area, this is a lot of bug splatter.
As many of you know, I have become a fan of Gyeon, so I picked up some Gyeon Bug & Grime Remover not too long ago, and this was the perfect time to give it a test.
Product Description
Remove bugs before they damage paint!
GYEON Bug & Grime Remover is a powerful cleaner that dissolves bugs and grime before they can cause permanent damage to paint. This easy to use spray formula is perfect for removing more than just bugs too; use it for road grime, tar, road film, and other common contaminants as well. GYEON Bug & Grime Remover is safe on your vehicle, whether it’s been treated with and SiO2 coating or not!
Driving down a bug-swarmed highway is never fun. Once you manage to get the windshield somewhat clean, you start to think about the dead bugs eating away at your bumper! When you make it home and it’s time to clean them off, don’t fall for one of those bug cleaning gimmicks, use a product that works, like GYEON Bug & Grime Remover.
GYEON Bug & Grime Remover makes bug removal easier. You won’t need an improvised scraper or a coarse scrubber that could damage the surface. All you’ll need is a couple of sprays of GYEON Bug & Grime Remover and a quick rinse and your vehicle will be bug free! GYEON Bug & Grime Remover is essential for preventing the damage that caustic bug guts can cause.
400 ml.
I was really excited about this product since it is advertised as a "touchless" solution to bug and grime. Whereas other bug removers suggest that you spray and agitate with a special sponge, Gyeon has no such requirements and furthermore states that it is safe for your coated car, which is nice since the Highlander has C1/EXOv2.
Price
$10.99 on AG and ACC
Review
The instructions state
[FONT=&quot]Spray a moderate amount directly on the surface. Leave to soften the contamination. Rinse with a pressure washer and a large amount of water. DO NOT use on hot paint or in direct sunlight. Do not let dry on paintwork or trim. The product is also environmentally friendly.
[/FONT]
Frankly, I didn`t know how much was a "moderate" amount. That was problem number 1. I sprayed somewhere between what I thought was light and liberal. It then stated to leave the product on to soften the contamination. I wasn`t sure how long that should be, but on another retail website, it suggested 1-2 minutes. I was concerned about letting it dry on the paint and trim (it was in the mid 70s), so I let it dwell for about 2-3 minutes. It`s quite possible that wasn`t long enough, but after that time, parts of the paint were getting pretty thin and I was concerned the product would dry out.
I did not agitate the product as stated on the label of the bottle (despite what some other website retailers suggest).
Here is a video of the application and the removal, which was done with a high pressure hose (not powerwasher as suggested by the manufacturer).
You can see that after the spray, soak and wash that the majority of bugs, splatter and grime are gone from the vehicle. However there are some bulky nasties still present on the vehicle. It required a general wash to get rid of these remnants and they were easily managed by a chenille wash mitt and Rupes m101.
So, one could look at this two ways. From one perspective, after spraying the Bug & Grime Remover and hitting it with the hose, the vast majority of the insect splatters and guts were eliminated from the vehicle. Another way to look at this was that the product didn`t work entirely as advertised and required some agitation and physical removal.
I decided to perform a simple test.
On the opposite side, I had a fairly equivalent amount of splatter and stuck-on Hymenoptera. I decided to blast this side with the hose to see if I could get an equivalent cleaning effect with just the pressure of the water without the Gyeon Bug & Grime. Here`s the video.
As you can see, the hose knocked off the vast majority of the bugs and splatter, but the Gyeon Bug & Grime did help achieve a bit more removal.
Opinion
Gyeon Bug & Grime Removal is a fairly easy to use spray for bug and grime removal. Unlike other bug and grime removal sprays, this one is stated to not need any agitation or scrubbing. It is safe for coated cars. In terms of these two claims, I don`t fully agree with the first one. After the first test, there were visible components of bugs and grime still on the vehicle that were removed only with agitation during a full 2BW. However, it is clear that during the second test, water alone was not sufficient to remove the bugs and grime and that Gyeon Bug & Grime Remover did help. Even still, there was some grime left over.
I`m not entirely convinced that this is a product that will consistently work without some agitation of scrubbing. It does help, but it may not be all that more helpful than water alone followed by a 2BW or possibly rinseless wash.
This brings to mind a post by Mike Phillips concerning bird bomb removals. He takes a microfiber, saturates it with water and leaves it on the bird bomb. The bird bomb comes off without a problem. Why are there bird bomb removal products at cost? Do we actually need bird bomb removal products, or is water saturation the key? Similarly, do we need a bug removal product or is water saturation the key?
A criticism could be that I didn't use a pressure washer. I don't find this criticism to hold (excuse me) water. Why? Given that the regular hose knocked off the majority of bugs and grimes, I'm pretty confident that the pressure washer would have knocked them off without any assistance from the Bug & Grime Remover. Didn't perform that test, but that's my suspicion.
Another interesting question to answer is whether this product is less helpful on coated cars. If coatings offer the best protection, special products to remove bug splatter may be unnecessary. More testing is required to answer this question, and opinions are invited.
At this point, however, I am not convinced that s specific bug splatter removal product is that beneficial.
(In case you're curious, the trim is dressed with 1 week old McKee's Trim Restorer.)
nice review, how you compare it to this?
autogeek_2272_144756468
I don't know, VISITOR. I haven't tried PB yet.
I haven't really seen a need to use a bug remover until now. I think the crux of the review comes in the closing moments when I pose the question of whether such a product is needed when a jet of water does most of the work.
I've never understood the idea behind bug specific removers. I'm willing to bet a quality APC will do just as good.
Dried up Bugs are not good for your paint work, as the bug guts can have some nasty stuff in them,
Fist make sure the product is (headlight safe) dont want to cook your UV clear coat off.
Your bug splatter is miner we here is Tasmania have a 6 month period of bugs starting from October-March
at the moment it's flying ants but can range from Big Moths,grass hoppers, etc
I use Bowdens own (Bugger Off)
Have any of you ever heard of using diluted hydrogen peroxide for bug removal? I had a neighbor that swore by it, although I don't know the dilution. And I don't know if she was doing this on paint, in addition to glass.
Would this be bad for paint?? I'm not a chemist... and am apprehensive when it comes to "home remedies" on my vehicles (not so much on myself).
Thanks for the review. I always use Bug Squash, but even as good as it is, I think agitation is always going to be needed if your dealing with moderat to heavy levels of bug spatters. The larger bug simply make too much of a mess to hose off.
I thought your comments about not having too many bugs in the Chicago-land area was interesting. Last year when driving home to St. Louis from Joilet after a track day last summer, I actually had to pull over somewhere between Bloomington and Springfield to wash my windshield so I could see. My wipers and washer fluid weren't cutting it. I've had similar issues between St. Louis and Tulsa, but the clouds of bugs in central/northern Illinois seemed much worse.
Most all APC works well, dilute it though and it might "wear out" your topcoat so you may need a reapplication in the general area.
I love these bug sponges, this link is for Lake Country but there are various suppliers just here at AG,
Lake Country Ultimate Bug Sponge, bug and tar sponge
I haven't had any issues with paint marring but check your results before going crazy with it.
Central Illinois? Where's that? Always thought Chicago was the same thing as Illinois!!!
Maybe some other Chicagoland people can chime in, but I've really had no bug issues - at least no issues in which I would have felt the need to get a bug remover - in the 9 years of being here.
(Sent via my mobile device...)
Dried up Bugs are not good for your paint work, as the bug guts can have some nasty stuff in them,, etc
Agree fully.
Points being made, however, is not whether they have nasty stuff. Points being made are that Gyeon would benefit from agitation in my opinion and that a good jet of water and routine wash is probably sufficient for most.
Spectacular and very detailed review as always Kevin! Always look forward to your reviews. I thoroughly enjoyed the entire article including videos.
How long has it been since your wife and kids arrived from the road trip?
I don't think any bug removal products would work without agitation especially the longer you let them bake on the surface. The fact that it helped remove bugs compared to the untreated side is a win for me. But the mfr did state that their product should work without agitation. Maybe they meant whatever's left softens the bug guts and makes them easier to remove during your wash?
I have been employing the water soaking of bird poo and bug guts way before Mike Phillips created his articles. My logic and reasoning for it came from washing dishes. You know how hard and nasty food/sauce/grease is to remove once they harden right? Whenever I encounter such problems, I just soak the plates/bowls/containers with water and come back an hour or so later to wash it. Now, the hardened food/sauce/grease wipes away with ease. So I used the same approach with hardened bird poo and bug guts. Wiping them off is a lot easier after they've been soaked from water (even for only 5 mins) as opposed to trying to wipe them off immediately.
Mike Phillips also has an article on soaking dried bug guts to make removal easier:
Tips & Tricks: How to remove dried bug spatter or bug guts
I think that the approaches are different. The water saturation method softens the bug guts to make cleaning them off easier. The bug removal products chemically attack them and break them down to make removal easier. Not entirely 100% certain on the latter as I'm not a chemist LOL!
Thanks, Marc.
My wife said the bugs were from the trip back, and she arrived on Saturday AM. So, Friday/Saturday. I washed the car Sunday and posted the review, so they had been present for at most 2 days. They were pretty crumbly and crispy when I touched them.
I agree with you regarding dried out food on plates, etc. Soaking them in water is the key, as I've found out with bird poo and as demonstrated by that Mike Phillips link you provided.
Agree fully.
No agitation would be the way to go, with the aid of a (high pressure washer) But with just a garden hose yes agitation is needed.
I dont think there would be a product on the market today where you could just spray and wet and walk away.
orange citrus.
