Review & How-To: BLACKFIRE Pro Ceramic Paint Coating Black Edition
What is it?
A 9h hardness ceramic paint coating that can last up to 5 years.
What does it do?
Seals and protects car paint while adding incredible gloss, depth and shine. The super hydrophobic effect creates a self-cleaning effect anytime it rains and washing and drying are faster and easier. This ceramic coating also offers superior chemical and corrosion resistance.
When do I use it?
After first washing and drying paint in new condition or after first doing any paint correction to older cars.
Why should I use it?
To protect your car's paint from anything that would attack it while give it a show car looking finish that washes and dries faster plus has a self-cleaning effect when it rains.
My comments...
Out of all the coatings I've tested this year, this is without a doubt the hardest coating I've used. The next day after coating the car, the suede microfiber cloth I used to wrap around the foam block, after the coating in the cloth had fully dried, the cloth was harder than I've ever seen. I include some pictures of it at the end of this article.
Victim Car - 2020 C8 Corvette Stingray
In order to really test out any product I need a car. Here's is a brand new 2020 C8 Corvette Stingray. Looks good here huh? Let's take a closer look with the Speed Master Swirl Finder Light.
It takes the right light to accurately inspect paint
Water spots and road film from driving in the rain. Not as clean as you thought after looking at the picture above huh?
See the "film" where the swirl finder light is lighting up the paint? There's "spots" but there's also a FILM.
If you're not sure what Road Film or Traffic Film is, here's my article on this topic,
Road Film - If you drive your car in the rain your car has road film
And because she was driven in the rain, the spots and road film are everywhere....
Here's the roof....
After washing - Water Spot IMPRINT RINGS
These spots or rings did NOT wash off. That's because they are actually an ETCHING that is IN the paint, not ON the paint.
If you're not sure what Water Spot Imprint Rings are, here's my article on this topic. Note, they will not wash off you MUST machine polish the paint.
Imprint Rings - A specific type of water spot on car paint by Mike Phillips
And light swirls
The Baggie Test
After washing the car, I inspected the paint using a clean, plastic sandwich baggie. There was LIGHT contamination that did not come off when I washed the car so before polishing I clayed the paint.
Detailing Clay
Anytime you can feel little bumps on the surface using the baggie test AFTER washing and drying the car, this is a sign of above surface contamination. Whatever these contaminants are - they have a strong enough bond to the paint that they did not come off during the washing process. So in order to remove them, the safest option is to use an fine or ultra fine bar of detailing clay. For this I'm using the BLACKFIRE Poly Clay and the BLACKFIRE Cay Lubricant.
Spray a section of paint with the clay lube...
For the bar of clay into a patty and then rub it over the lubricated section of paint.
When you feel the clay glide effortlessly over the paint - wipe of the residue and then continue this process over the rest of the car.
Paint Correction
My own personal rule is to always do at least one machine polishing step anytime I use detailing clay on a car. This ensures there's no marring left in the paint from the claying process PLUS it removes all the swirls, scratches and other surface impurities. Also, remember the Water SPOT IMPRINT RINGS in the previous pictures? Machine polishing will also remove these defects.
Medium to soft paint
Historically, Corvettes are known for having very had clearcoats. I found the clearcoat on this latest model to be on the medium to soft side of the paint hardness/softness spectrum. After some testing I found a light cutting polish with a foam polishing pad on my trusty FLEX CBEAST was more than enough to remove all of the paint defects and leave a crystal clear finish.
Always shake standing products first...
Apply some product directly to the face of the pad...
Then machine polish the paint breaking larger panels up into smaller sections.
It took me about 3 hours to machine polish all the paint on this old 2-door Chevy....
Clean, soft microfiber towels
It is SO important after investing hours of your time in the machine polishing step to only use clean, un-contaminated microfiber towels to wipe off any polish residue.
If you haven't read my article and watched the video on how and why to inspect your microfiber towels, I highly recommend doing so.
Secondary Paint Inspection
It's so important to be sure the paint looks right before installing the coating. Here's a few shots showing swirls-free, water spot free flawless black paint. Polishing paint is an art form but as long as you're using great abrasive technology you can't help but get professional results.
That looks tight and that looks right!
Continued....
How to install the BLACKFIRE Pro Ceramic Paint Coating Black Edition
One of the key differences between installing a ceramic paint coating versus applying a coat of wax or synthetic paint sealant is the step where you wipe the paint down with what is called a
Panel Wipe
A panel wipe is a clearcoat safe solvent that removes any polishing oils off the paint after polishing or any other substances so the coating can make a proper bond. For this Im using the BLACKFIRE Paint Prep and some clean, soft Cobra 530 microfiber towels.
Step 1: Mist a section of paint with the BLACKFIRE Paint Prep.
Step 2: Spread the product over the section and then flip to a clean, dry side to make the final wipe.
The goal is to leave perfectly clean and clear paint. For this step you'll need at least a half dozen towels. Repeat this process over the entire car.
Step 3: Install the coating
Fold a MicroSuede Cloth around a BLACKFIRE Coating Applicator.
Dribble a strip of coating in a line down the middle of the MicroSuede Cloth like this,
Spread the coating over a section of paint no larger than 3' by 3' using a crosshatch pattern.
Sweating
Most coatings lay flat on the surface and you'll see a rainbow color appearance as the solvents evaporate or "flash" off the paint. With this coating, you'll see the rainbow appearance and you'll also see the coating coagulate into beads and strips of product as it's flashing. Kind of the same way perspiration appears on you skin when you start to sweat.
This is normal for this coating. I'm not sure what causes this but it could be a high concentration of solids. The solids being the nano size particles of silicone dioxide. I've never seen this with any other coating I've used and my FIRST use documented how-to article for using coatings dates back to 2011 - maybe not as long as a few people in this industry but definitely longer than most.
LONG WORKING TIME
The reason you work up to a 3' by 3' area at one time is because this coating has a long working time, or slow flash time. This makes this product incredibly USER-FRIENDLY. This give you plenty of time to wipe the section coated to smooth out the coating and to also remove any excess. Coatings that dry fast become sticky on the surface and when this happens they can be difficult to remove.
The sweating appearance
When you see the sweating beads appear on the surface, this usually only takes around 45 seconds to a minute - it's time to gently wipe the area. When wiping the coated section the goal is to,
A: Continue to spread and smooth the coating over the surface for a uniform layer of coating.
B: Remove any excess coating before it sets-up.
Continue installing the coating to the rest of the car.
Here are the results...
First - let's inspect using a swirl finder light Inspection - the goal is no swirls or water spots left in the paint and no high spots
Beauty shots...
And here's the final results....
Nice....
Continued...
Products used
Just as important as telling you about a new product is also sharing what I needed to actually use the product correctly. It won't do any good to purchase any brand of ceramic coating if you don't also have all the other components needed to properly install it.
Pictured below,
6 each RUPES 7" Yellow Foam Polishing pads
Behind the pads is a FLEX CBEAST or the FLEX Cordless 8mm gear-driven orbital polisher - part number - FLEX XCE 8-125 18.0
BLACKFIRE Polish
MicroSuede Cloth & BLACKFIRE Coating Applicator
Cobra 530 microfiber towels & Cobra Storm Gray Edgeless Microfiber Polishing Clothes
Super hard drying coating
Normally, these small patches of microfiber suede are soft and limp.... look how stiff it is after the coating has fully dried.
This soft, limp MicroSuede Cloth is so hard it stands up on edge!
Take my word for it - you really don't want to leave any high spots anywhere on the paint. Make sure you inspect each panel after final wipe-off to ensure there are no high spots. This is where a hand-held swirl finder light will save you.
Car in focus - Looks great!
Coating in focus - this Corvette is now protected for up to 5 years!
More...
Everyone LOVES the Water Beading Pictures!
The next day I came into work and tested out the hydrophobicity.
Check out the surface tension this pro grade coating creates!
What do you think? Use this picture for Mouse Pad art?
Tight, tall and small, just how we like our water beading!
With this kind of surface tension this car is going to wash fast and dry fast and anytime there's a hard rain - the rain will do a Mother Nature's Wash Job for the owner.
Continued...
Review
Super easy to use. Incredible gloss, clarity and depth-of-shine. Easy application. Super easy to spread and wipe-off. And super long working time. Plus up to 5 years of protection as long as you use common sense and wash carefully. There's simply no downside to this coating. You get professional grade results but it's so easy anyone can use it. Even if it's your first time installing a ceramic coating.
Most coatings are easy to apply. A ceramic coating is basically a think liquid product that you spread over a section of paint using a crosshatch pattern going over each section 4 times. You go side to side and the front to back and repeat this twice for each direction. So there's really not a lot of technique required for the actual application. What separates some coatings from one another is the working time or the flash time. The flash time is simply how people describe the evaporation rate of the carrying agents for the solids.
Carrying agents = solvent
Solids = the actual coating component or nano sized particles of silicone dioxide
Now the wipe-off is where ceramic coatings can differentiate. A coating wit a very short flash time MUST be wiped off quickly or the solvents will evaporate so fast they leave the solids behind on the surface and they do what they're supposed to do and that's bond to the paint. If they are bonding and you are wiping, the feeling you get is the product is sticky or smeary, as it's going to be hard to wipe off the surface. That's where the BLACKFIRE Pro Ceramic Paint Coating Black Edition shines. Because it has a long flash time or working time, there's no complications for the installation process. Of course you should follow direction and work within the recommended window-of-time for wipe-off. But even if you lingered for a minute or two, the excess coating, also called high spots, will still wipe off easy as the product remains wet on the surface longer than most coatings. This makes it easy to use.
Strong Personal Recommendation
Even though this coating is super easy to use, I highly recommend having a great hand held light that you can use to inspect EACH panel after you wipe-off the coating to make sure you have not left any high spots behind on the paint. The reason why is because this is a CLEAR liquid - it can be difficult to see trace residues without the light. AND - if you don't remove these trace residue or high spots - after the coating fully dries, bonds and cures to the paint - in order to remove the high spots you're going to need a compound, maybe a polish to mechanically abrade the paint and thus abrade and remove the high spots. So when making the switch from traditional car waxes and synthetic paint sealants - I recommend you not only purchase the ceramic coating but also budget for a quality swirl finder light.
There are a number of excellent quality swirl finder lights on Autogeek.com including lights from FLEX, ScanGrip, Griot's, RUPES, SONAX and Speed Master.
On Autogeek.net
Continued....
Parting shots....
There's nothing like full sun, directly overhead to showcase and/or reveal the true condition of the paint. As the owner was driving his car out of the garage I snapped these Sun Shots.
Argh!!!! there's a Palm Tree growing out of the hood!
Have fun P.J. in you brand new Plastic Fantastic!
Pretty intense review and intense coating. Seems more hardcore than the WG and PBL new offerings, but I suppose time, protection and self-cleaning are the real measuring sticks.
WOW - I'm not huge on water beads like others are, but dang, those are some nice looking beads ! !
Nice job, Blackfire!
Great work, Mike!
Great results Mike. The sweating effect is a nice touch.
Question for you, will both coatings stay in the blackfire line up?
This may be a question for the chemist. Other than the claimed longevity and sweating effect, what differentiates this blackfire black edition coating compared to the blackfire pro ceramic coating?
Yeah, sorry to say I don't know much about the "why" it does this as I don't have a relationship with the chemist for this product.
Yes, as far as I know but you would probably be better off to call Customer Care directly and check with them as they tend to be more in the loop for this type of thing.
1-800-868-3011
Good questions and our marketing department may have more answers than I include below, but from the info that has been provided to me,
1: Up to 5 years protection/longevity
2: Harder finish - the stated hardness is 9h
3: Increased hydrophobic properties i.e. higher surface tension thus better water beading
4: Water sheeting
5: Better chemical and corrosion resistance
6: Better self-cleaning effect due to higher surface tension, faster washing and drying also
That's off the top of my head and after re-reading the store page here,
And the info I included in my review.
Great questions, thank you for asking.
Thanks Mike.
I was able to get some answers on the BF IG page.
Given the nature of the coating, are multiple coats recommended? If two coats are recommended how much time should we wait between coats?
Mike,
Excellent review as always. Been following your form posts for a couple years as I started down the paint correction and coating rabbit hole.
Based on your review I decided to try out the BLACKFIRE Pro Ceramic Paint Coating Black Edition. Had to wait about a month over the holidays as it was on backorder everywhere -- even on the manufacturers website.
Anyway, just finished up a light paint correction and 2 coats of BLACKFIRE and I can say it went exactly as you described. The amount of workable time was amazing easily in the minutes. I even caught a few areas with a correction light that had some haze like 15 minutes later that buffed right out.
The car was a 2 month old Racing Yellow Porsche 718 Spyder with 2100 miles.
Unsure how much weather affects the product, but I was in a heated garage heated to around 70. Humidity wise was a little higher given the recent rain so probably around 80%.
Here is a e-mail I received from BLACKFIRE on wait time between coats and SiO2 toppers:
Hello,
If you want to apply multiple layers of coating, wait an hour between each layer. adding a second layer will have noticeable positive improvement to the gloss and protection of your coating. 3 layers will provide a small amount of additional protection, but not a significant amount. Adding a 4th layer would not provide any additional protection or gloss and is not advised. We recommend waiting a minimum of 24-48 before applying an Sio2 spray sealant as a topper.
Thank you,
Michael
I did notice additional depth and gloss with the second coat.
Thanks again.
Mike,
Hello,
Thank you,
Michael
Thanks again.
Hi Michael,
First - Because this is your first post to the forum,
Welcome to AutogeekOnline! :welcome:
There's no way I could ever create the kind of in-depth content like you see in this review or any of my articles on Facebook and Instagram. I love the spontaneity of these other two platforms but as far as sharing any substantial information they are useless. So thank you for joining the forum to interact.
Second - Thank you for your well-written summary of your experience with the new BLACKFIRE BLACK EDITION. It's a very stout coating. For anyone that want's absolute bullet-proof protection - it's good.
You also need to make 100% sure you wipe off any high spots or excess product. Once this coating dries it's solid. It will never "wipe" off. You can compound it off but you'll never wipe it off.
A few weeks ago I used the BF BE on a brand new black C8 Corvette. I let my brother-in-law help me. I applied the coating, he waited about 45 seconds to a minute and then wiped each panel to remove any excess. After we were done I went around the entire car to inspect our work. I found 3 places with high spots. For each area with a high spot I had to polish the coating off, re-strip the paint and then re-apply the coating.
It was a great learning experience for PJ, my brother-in-law as he found out how IMPORTANT it is to make 100% for sure you remove all the coating. He also learned how important it is to have a GREAT hand-held light for inspecting for high spots.
But best of all - he loves how all he has to do to get his Corvette clean is blast it with water and then dry it with a leaf blower.
Here's my write-up for this C8 Corvette
2020 C8 Corvette Detail by Mike Phillips
The paint is soft enough on the new C8 Corvettes I was able to correct it with a fine cut polish, a soft foam polishing pad and a cordless buffer.
Re: Review & How-To: BLACKFIRE Pro Ceramic Paint Coating Black Edition
I bought the grey Microsuede cloths for $9.99 and the Gyeon applicator before I read this article. I hope this combo works good for applying this product. If not I have two microfiber applicator blocks on standby.
Great review and how to!
The website says you can do 2 coats for added gloss and protection.
Here's what it says- -If you want to apply multiple layers of coating, wait an hour between each layer. adding a second layer will have noticeable positive improvement to the gloss and protection of your coating.
I'm thinking if I have enough towels I'll try two coats on an upcoming project.
Sent from my SM-G975U using Autogeekonline mobile app
:updated:
It's been 8 months since I coated this old 2-door Chevy,
PJ is NOT a detailer. He appreciates a great looking car but he's not the kind of guy you would ever find hanging out on a forum like this to figure out how to best take care of his cars.
I've made sure he has a quality wash mitt, some good car wash soap, etc. And to this day, the finish on his black Corvette is still swirl-free.
The BLACKFIRE Black Edition is the real-deal when it comes to a professional grade ceramic coating.
Treat it with respect or you will pay the price. The info about this coating says you can wait up to 5 minutes before wiping the panel just treated. Go for it if you feel your skill level is high. Me? I wait about 45 seconds and then start wiping the panel just treated.
THEN - I inspect with a hand-held light to ensure I've removed 100% of the coating.
If you do NOT remove all of the excess coating - the high spots will require a compound to remove.
Also - if you have NOT read my below article - then read it. And if you don't have a GREAT hand-held inspection light then get one.
I'm serious. Been there, done that. Don't ever want to do it again. (have to compound high spots the day after)
Installing a Ceramic Paint Coating? You MUST have a GREAT hand held light to avoid high spots!
Just trying to help folks...
:cheers:
Thanks Mike! I just got my bottle of BLACKFIRE Black Edition yesterday. I'm exited to try this stuff out.
Autogeek was kind enough to send me a couple of samples and a 30 percent discount card with my order. That was a really nice surprise!
