mixdemotionsfox
- Mar 31, 2020
- 19
Getting ready to install this for the first time this weekend. Have only used UK3.0 prior to this. Is this coating safe for PPF? Cant wait to try it.
I would say "yes" but apply, wait about 35 to 45 seconds and then gently wipe the treated area.
Mike Phillips said:I would say "yes" but apply, wait about 35 to 45 seconds and then gently wipe the treated area.
Thank you sir. Appreciate it.
Ended up. Doing a friends older truck.
She was a little ruff around the edges but it turned out very nice I think. Coating seems to be holding up well. We have had an abnormal amount of rain since install.
Normally, these small patches of microfiber suede are soft and limp.... look how stiff it is after the coating has fully dried.
Hi Mike,
When doing a 3x3 section for a hood with MF suede, can it be reused be used on the next part of the hood or will the coating product on the MF suede flash at the same time/rate as the ceramic coating on the car?
Same question for removing coating with MF, one section of a panel and done or reusable for next section of a panel ?
I bought the BF black edition ceramic, just figuring how many towels I need to have on hand for my giant truck.
Hi Mike,
Hi Mike,
Anyone with insight?
I can't personally speak for the Blackfire coating, but with most other coatings out there you can use the same applicator for the whole vehicle, as long as it stays clean.
If it gets dirty or you drop it on the ground, I would use a fresh applicator.
Using the same one will reduce product usage, and because you're continuously pouring more onto the applicator, the solvents will keep it from hardening until it dries.
I rarely use the rigid foam blocks with the microfiber suede patches any longer.
Grumble grumble…bought a 30 pack of MF suede based on this article.
Thanks for the info though. Always appreciated.
First - Send me your shipping address and I'll send you some of the Speed Master Foam Block Coating Applicators for free. I'm assuming and hoping you live in the lower 48 states otherwise shipping becomes a hassle - at least for me.
Second - When I wrote this review, the BLACKFIRE Pro Ceramic Coating "Black Edition" was paired with the MicroSuede Cloth and the BLACKFIRE Coating Applicator like I shared in this picture.
Fold a MicroSuede Cloth around a BLACKFIRE Coating Applicator.
Not only does Autogeek want me to show these items with the coating "because" that's how they are sold on the AG site - BUT the black and red foam block coating saver applicator I now like, use and recommend was not yet available.
At least not to me via Autogeek inventory.
So no harm intended, I shared what I was responsible for sharing and also what was available.
Make sense?
So e-mail me your shipping address, I hope you live in one of the lower 48 states and I'll get them shipped out today.
[email protected]
:cheers:
Mike,
When I ordered the Blackfire lit, I didn't receive the suede applicators, but rather a blue microfiber block. Just wondering if the foam applicator you referred to is how I should install for best results since this will be my first time with this coating. Any chance of getting one to try?
Mike,
I've applied Blackfire Pro Black Edition on my red Tesla. It was so easy and it came out great! When I washed my car the other day, I noticed 2 tree sap droppings and when I tried to scrub them away, it seems like it has eaten into the coating and now left a mark. What is your suggestion to fix this? Is there a product that I can use to remove it or do I have to polish off the entire coating and recoat it again? The unfortunate thing is one dropping is right smack in the middle of the hood and the other is on the left side fender. Thanks in advance.
