StangFan25
- May 14, 2013
- 738
I was sent a bottle of Hyde's Serum Rustopper to test out and write a review. As you will see, my rotors were in pretty bad shape, so I was excited to give this product a try!
Product Info:
Hyde’s Serum Rust Stopper, rustopper, anti-rust solution for wheels
Hyde’s Serum Rust Stopper puts an end to a common problem that plagues every detailer and car care enthusiast after a car wash – rusty brake rotors! Through the use of advanced chemistry, Hyde’s Serum Rust Stopper blankets your brake rotors in a protective film that prevents “rust dust” – the initial brake dust on clean wheels that occurs after washing. Application is as simple as spraying on and walking away!
Directions:
On to the review!
First, a video, showing the product doing its thing. Wheels were cleaned per directions(washed with Zaino Shampoo, sprayed with DP Wheel Cleaner, used a Daytona Speed Master Jr.), while still wet, HSR was applied and allowed to dry.
For the life of me, I cant get the video to embed, despite following the instructions... so, here's the link..
Hyde's Serum Rustopper - YouTube
Pictures...
Before and after, with a side by side on part of the rotor.
As you can see, pretty bad shape...
I did a side by side for a before and after, after is on the top, before next to it...
The finished shot...
I believe the product did a fairly good job. Did it completely remove all of the rust, no, but I didn't expect it to. Mine were real bad. It did remove quite a bit. I believe I may need one or two more applications to get the desired results. Unfortunately Winter is fast approaching and I don't think I will have another chance until after Winter.
Easy to apply, simply spray on and let dry, wiping any left over product. I didn't notice any strong chemical smells with the product, I have a chemical Sensitivity so I didn't want to try smelling it too long
After applying to all 4 wheels, I still have over half the bottle left, so great value there!
I'd like to follow up on the durability of the product, but as I said, Winter is almost here, and I wont be able to provide fair results.
Thanks to Nick for sending me this product to review, and thank you to Ryan at HydesSerum!
Video and pictures were taken with a Nikon D800 and 24-70mm F2.8 lens. No editing was done to the pictures or video. Only resizing for the images. This is my first review, and I hope it offers some help to those considering Hyde's Serum Rustopper!
Questions and comments welcomed!
Product Info:
Directions:
- Ensure wheels are clean and cool to the touch.
- After cleaning wheel and brake system, rinse thoroughly with water.
- While brake rotor is still wet, spray Rust Stopper liberally on brake rotor surface in a sweeping motion and allow to dry.
- Remove any over spray with soft microfiber towel
On to the review!
Pictures...
