Review: LC HD Orbital Pads
Yes Mark I did. To be exact I'm using an exact fit backing plate from Kevin Brown measuring 5-1/4". It fits perfect :).
Are you using pre production LC HD pads?
Cause I have a KB exact fit 5 1/4" backing plate. It's not a perfect fit. 5 1/4" is a little too big for the 5" velcro on the LC HD pads. Using the standard Rupes 5" backing is much better fit since actual measurement is 4 7/8".
Nope just the final versions. Mine fit great with no problems.
I know these pads are designed for large throw machines, but can they be used successfully with a PC? TIA
They probably could, but I wouldn't see any real advantage to using them, in fact I think a standard pad would probably work better due to sizing.
