Rsurfer
- Jan 26, 2007
- 14,159
- 26
Quartz; Sand; etc.? :e ek:!
But it's on the fine side.
In the video you say “soap does not create water spots, water creates water spots”
I would tend to agree. I also can’t help but think that if someone were to be washing a black vehicle in direct sunlight and using hard water from the hose to rinse off the soap, that they could still wind up with unsightly water spots if they were to fail to dry the vehicle off in a timely manner, even if they were using this soap.
Or does this soap somehow even prevent the rinse water from creating water spots?
I would think that this soap used in conjunction with de ionized water to rinse it off would make for a truly complete sun safe wash experience, free from any possible water spots.
I haven't used this yet, but from what I understand the suds now create a "barrier" which when rinsed off with regular tap water, the water spots left behind won't stick to the paint. You should just be able to wipe them off easily when you do your final wipe. Anybody, if I'm totally wrong, please correct me.
I seem to recall someone (maybe Nick) saying it would not prevent water spots once rinsed. That makes sense because I'm not aware of any product (even a coating) that prevents tap water from spotting once it dries on a car. I've used the product on an unprotected black car in direct sunlight and can attest that the soap can dry on the paint without spotting. But I did not let the rinse water dry to test that out.
Suds create a barrier between them and the oncoming water so that the soap doesn’t leave water spots... But what happens once the soap is rinsed off? What protects the the rinse water from leaving its own set of possible water spots? Because according to WRAPT, the soap used standalone on a vehicle with bare paint saw no beading or sheeting after the bucket wash.
So that’s why I ask: What would prevent any possible water spots from the final rinse in less than ideal conditions?
I’m more than fine with being wrong if that’s turns out to be the case. I’m just curious that’s all.
