Eldorado2k
- Nov 9, 2015
- 14,500
- 607
Ok, my 1st question is: On the video showing the full size Master Blaster, did you run it at its full power? Because it sounds like you only flipped 1 switch... Either that or you flipped both switches at the same time, but based on your own word, that wouldn't have been possible because that would've tripped your circuit breaker...
So you paid to have a 20A outlet installed specifically for the Master Blaster^
....Yet you say this happens?^ I dunno about you, but if I paid and went through all the trouble of that and it didn't even work for the 1 thing I specifically had it installed for, I'd be livid...
Did you at least call the electrician and get you money back?
You require a 20A outlet to run the Master Blaster. I paid $125 to have a 20A outlet installed.
You guys are lucky!!!
I don't throw both switches at the same time either... But after about 5 minutes of using it with 2 motors on, the circuit breaker will trip.
If I turn both motors on simultaneously, the breaker will trip immediately.
