Review: Meguiars Ultimate Protectant
CEE DOG
Introduction:
About 2 weeks ago I got to use this product which Shane sent me. Thanks for the sample Shane!
Product Description (from AG website):
Meguiars Ultimate Protectant utilizes breakthrough UV clear coat technology to offer unbeatable protection to interior and exterior rubber and vinyl. Plus, it brings a deep, dark shine to treated surfaces. Meguiars Ultimate Protectant lasts longer than conventional protectants and breathes new life into rubber, plastic, and vinyl auto surfaces!
Initial Product Observations:
1.- Packaging: N/A
2.- Directions: Simple
3.- Consistency: Lotion
4.- Color: White
5.- Scent: A hint of citrus I think?
6.- Size: 12 oz.
7.- Price at time of review: $9.99
8.- Manufacturer: Meguiars, Inc
9.- Made in: The USA
Products used for prep, during application, or removal:
1.- Nitrile Gloves
2.- Optimum Power Clean
3.- Flex 3401
4.- Edge Flex Adapter
5.- Orange 4” pad
6.- Meguiars M105
7.- MF towels
8.-
Yellow Foam Applicator
9.- Meguiars Ultimate Protectant
00-Conditions
Method of Preparation:
All of the black trim around the windows as well as the door handles were cleaned with Optimum Power Clean and then polished with Megs 105 using the 4” light cutting pad. After polishing with M105 it looked a lot better but there was nothing I could do about the many fine cracks in the plastic. After being polished the trim was cleansed with P21S Total Auto wash along with the rest of the polished vehicle. The faded gray bumpers were simply rinsed with the excess Optimum Power Clean runoff during the initial wash phase.
Application:
Using a foam applicator I applied MUP to the front bumper using overlapping back and forth movements. A portion of the front bumper still had UTTG on it so I applied the Megs directly over it. On the rear bumper I did not apply it over the drivers half (currently coated with DG 531) Using the same foam applicator I applied MUP to all the door handles as well as all plastic and rubber trim around the windows.
Video/Audio I:
Video/Audio II:
Observations:
I found the best means of application was working the product in through repetitive back and forth or overlapping circular movements. It applies fairly quickly and couldn’t be easier, although a little more product is needed than other trim products I’m used to. As I was applying Meguiars there where a couple times I got just a bit on the paint near the rear bumper. As I was finishing up the rear bumper I had to run inside to eat lunch. When I came back out I tried to wipe off the bit that had found its way onto the paint. It was on there pretty solid but a little DP Rinseless Wash took it right off. Please rejoin me after the pictures for the Pros and Cons.
Pictures:
01-Before
02-Before
03-Before
04-Before
05-After M105
06-After M105
07-After M105
08-Pad (4”) on Flex 3401
09-Pad (4”) on Flex 3401
10-Pad (4”) on Flex 3401
11-After Meguiars Ultimate Protectant
12-After Meguiars Ultimate Protectant
13-After Meguiars Ultimate Protectant
14-After Meguiars Ultimate Protectant
15-After Meguiars Ultimate Protectant
16-After Meguiars Ultimate Protectant
17-After Meguiars Ultimate Protectant
22- After Meguiars Ultimate Protectant
23- After Meguiars Ultimate Protectant
24- After Meguiars Ultimate Protectant
25- After Meguiars Ultimate Protectant
26- After Meguiars Ultimate Protectant with Tape Line
27- 50/50 Meguiars Ultimate Protectant VS. Nothing
28- After Meguiars Ultimate Protectant with Tape Line
2 WEEKS LATER
18-After a Rainstorm
19- After a Rainstorm
29- After a Rainstorm
Pros:
1.- Simplicity of Application
2.- Darkens Trim
3.- Dries to a non greasy finish
More Pro than Con:
1.- Durability: After a couple weeks its done a lot better than I expected.
2.- I am happy with the product holding up to the rain. I didn’t find any streaking from the rain on any of the window trim or door handles. There was a streak or two on the bumper after rain so this dropped it to the “More Pro than Con” category.
Cons:
1.- More product is needed than what I am used to.
Food for thought:
At a half or a third the price of Ultima Trim and Tire Guard the price of Meguiars Ultimate protectant seems great. It is a good price but if you compare the amount needed and the durability of UTTG the Ultima is much cheaper in the long run. Other than Ultima and Duragloss I think this may be the best trim product I’ve used so far.
Once again you are the MAN!!!!! Very nice review!! Looks like a great OTC product with a very affordable price! For me I will be sticking with the UTTG tho!
Great Review Corey once again!!!!! Thanks for taking the time to do these reviews.
I've been using UTTG on the exterior and the UP on the interior of my dd and have been very satisfied with results! Both products are great products and UP being an OTC, with a decent price,works for me! Thanks again for the review! :props:
Nice review DOG! I found UP to fade overnight compared to UTTG or DG 531. It might have been my method of application, but I applied it just like you. :dunno: I'm going to give one more product a shot(new CG G6 trim protectant) and if that doesn't rival UTTG, then I'm done experimenting with trim guards for awhile.
Great review Corey. I used UP this weekend as well I found it to be pretty good. I used in on the interior but want to try it on some exterior trim to see how it holds up to UTTP.
Thank you Dr!!! I will stick with UTTG as well but I did like it.
Thanks dad!!! I should try it on the interior! I bet it would be great for the SL dashboard.
Thanks Mark! Sorry to hear that but thats very interesting. Weird...
I haven't tried the CG but I have 98% certainty that no product is going to hold up to UTTG especially for durability (unless you spend 58$ per ounce). After some of the things I've seen with UTTG the stuff just doesn't come off for a very long time regardless.
Thank you, let us know what you think on the exterior :xyxthumbs:
Nice review Cee. I like this product a lot. I have used both this and UTTG. Here is what I have found.
For hard plastics, trim, cowling ect, Meg UP is the winner last several weeks, though rain and washing. It was the first dressing that I have ever used in my years of detail that lasted that long. I use very little product. About a quarter drop does my side mirrors and side steps on my truck. You may have been using to much is why you had to work it in a bit.
On soft plastics like my tonneau cover UTTG blows the meg away. I put Ultima on my tonneau around Nov. Its still beading and looking good. Megs worked but not nearly as long.
Neither product runs onto the paint. The choice between the 2 really comes down to your budget.
Nice review Corey! :dblthumb2:
So, would you pick UP over PBTR? Also, I think you were using a bit much as well. There is a sticky thread on MOL on how to apply UP that you might be interested in - How to apply Ultimate Protectant - Car Care Forums: Meguiar's Online. IMO, for an OTC product, Ultimate Protectant kicks Back to Black butt any day of the week, without a doubt. Thanks for the review! :props:
Love UP on the plastic windshield cowling and on the textured black plastic side mirrors on my Hyundai. Apply a small amount to a foam pad and work the product in, similar to applying a cleaner/wax to paint by hand. Buff with a microfiber and you're good to go.
Hey Corey,
Great job on another product review! :props:
I did a similar test last summer and came away with pretty much the same results. I was used to using Poorboy's World Trim Restorer and this was quite a bit different so there was a relearning curve to it.
I was a bit skeptical initially but after some experimentation and after it dried I too was surprised and impressed with its look and staying power after a rain storm..
Awesome job my friend! :dblthumb2:
Thanks guys!
I appreciate the tip Shane. I felt like it got darker when I applied a little more and I never got runs so I'm not sure but next time I'll revisit the application method as you show.
Bobby, glad you reminded me its update time! Just yesterday (3 weeks since application) I took a look at that car and I can see it fading a little. It still looks very good but the UTTG from awhile back is noticeable darker now. I'll post some pictures in the next day or so.
Very user friendly product
Lasting longer than I expected and looking good...
Won't touch UTTG in durability
You are an amazing review man! Great job as always, I like the videos, we get to see and hear how crazy you are about detailing!
This explains why that Sky shines so bright!
MU is the best product I have used on running boards. It looks great aYet another masterful review Corey!nd isnt at all slippery. Its durability does not rival UTT IMO.
Great job on the review CDog :props:
Megs has a nice performing OTC line (and Professional line for that matter).
Corey, do you find UP to darken the trim more than UTTG?
On the badly faded trim I've tested I do find the UP to initally be just slightly darker than UTTG. After a few days to a week I would say they are even depending on the weather and then within 2-3 weeks the UTTG is noticeable darker.
Thank you Meghan! :o I really appreciate that and Sky thanks you as well.
Thanks for the added info and the compliment Jim! Another product with which I agree on your analysis of.
Thanks mdb :dblthumb2: They have sooo many products to me it is just overwhelming but they definitely have some winners. I have used a few of their products and can only think of 1 that I have been dissapointed with.
Was this review on Meguiar's Ultimate Protectant or Ultimate Protectant Trim Restorer? I was at Advance Auto and noticed they had both.
Its the same product, UP is last years label, UPTR is this years label.
Thanks for answering that Jeff. I didn't know the answer :)
