Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Review: NEW Lake Country Microfiber Pads - 2 step swirl destroyer and shine maker!
Lake Country is not only one of the largest and oldest buffing pad manufacturer on the planet they also have the reputation of developing and introducing the most innovative and high performance pads on the market.
Here's their latest pad introduction to the market the Lake Country Microfiber Pads. These new pads are available in both cutting and polishing versions and available in 6 1/4" - 5 1/4" and 3 1/4" sizes.
David Patterson sent me samples of all their new Microfiber Pads and I put them to the test on a horrendously swirled out 1940 Pontiac 5-Window Coupe Streetrod.
SWIRL DESTROYER
Here's my test car and for the testing I'll be using a simple and easy to use Porter Cable 7424XP dual action orbital polishers. This is the safest and easiest tool there is to learn how to use to machine polish paint. When fitted with thin pads like these new Lake Country Microfiber Pads and a high quality compound like the SONAX EX 04-06, you turn this dual action orbital polisher into a SWIRL DESTROYER!
Microfiber as an abrasive booster
Fibers are a gentle form of abrasive. Working in conjunction with the abrasives in the SONAX EX 04-06 you get 2 things working for you to remove swirls, scratches, water spots and oxidation.
Always center the pad onto the backing plate for maximum performance with the least vibration
Apply the SONAX EX 04-06 directly onto the face of the pad.
To show the before and after difference I've placed a strip of painter's tape on the hood.
Machine compounding
Holding the pad flat to the surface, make slow overlapping passes in a crisscross pattern using the LC Microfiber Cutting Pads
Machine polishing and sealing
For the second step, instead of using a polish I've chose the SONAX Paint Cleaner which is NOT a paint cleaner but an AIO or cleaner/wax. It has the cutting power of a medium cut polish but it includes synthetic and natural protection ingredients to make this a great one-step product or in the way I'm using it here to clean up any haze left by the compounding step to leave the paint protected as well as glossy and shiny. Thus a great 2-step approach to de-swirl cars using the power and effectiveness of microfiber in the equation.
First I'll apply some product to prime the face of the pad...
After priming the pad add 5-6 more drops of product in order to have enough product to refine the results from the first step while polishing the paint to a high gloss and leaving behind a layer of protections.
Make 5-6 section passes...
Wipe off the residue...
Remove the painter's tape...
Now let’s inspect the results using a FLEX Swirl Finder Light
Before - Swirls throughout the finish
Cropped out section from the original above pictures...
Here's the light on the tape-line...
Here's the side that was buffed using the 2-step swirl destroyer and shine maker process...
Reduce time, labor and steps while maintaining pro quality results
Leveraging the performance of Lake Country microfiber pads you can turn out show car quality results in two steps.
On Autogeek.com
Lake Country Microfiber Cutting Pads
Lake Country Microfiber Polishing Pads
SWIRL DESTROYER
Machine compounding
On Autogeek.com
