Chris Thomas
Optimum Guru
- Dec 21, 2007
- 1,824
You're quite welcome Corey, thanks to you for a very thorough review!
I always squeeze the excess out of my MF or Mitt before going to the panel. There is plenty of cleaning solution on the MF and on the Opti Mitt without dumping it all in the floor. Corey is uber careful with his baby and that's why he goes straight to the paint without ringing. I probably have more miles on my OptiMitts than anyone and I can tell you that you don't have to use that much solution and if used properly you won't have anymore in the floor than with a MF.
Also, tucking the lanyard in is fine, but I don't recommend tucking it in and pulling it thru the hole like Corey did in his review. Something like that could start a tear on the corner that could easily travel once started.
Got to use mine for the first time today
This happened immediately when I pulled it out of the water for the first time. Its like the yellow foam can't hold the extra weight of the water.
Bad batch?
It's clear that optimum has a problem on their hands.
It is being looked into and all those having problems should just contact your supplier. It is unclear if there is a bad batch or if the yellow foam is too porous making it weaker, but Optimum will make it right, no worries fellas. I have also advised a larger opening if they decide to revise it.
I wouldn't go that far considering the results others have had. Could be ours came from a bad batch or got caught on something before being shipped.
Thanks for adding your well documented thoughts Bill. They are much appreciated. I feel the same way... I do not feel comfortable pressing hard enough to be sure the entire surface contacts the paint either.
Have you tried plush towels for ONR yet?
