ViperGuy21
- Apr 6, 2015
- 802
I received this product from Steve and Dwayne as part of the recent giveaway on Autopia. I want to say thank you to you two gentlemen for this opportunity to beta test some products for you!
These two pads had Sonax Cutmax and Sonax Profiline EX 04-06. I had to get some pads dirty so I went ahead and buffed out the tailgate on my dad's truck.
Befores:
I saw that donbeezy used the 'soak' method so I decided to try the other method and spritzed it on the pads, let it soak in, then placed it on a grit guard in a bucket and sprayed it down with a jet stream of water. The pad with the compound required a second round of cleaning with a little agitation from a brush to get all the little particles out of the pad, but that's not a big deal by any means.
After round one on the compounding pad:
You can barely see the little white specs left
Afters:
Thoughts:
I really liked this product overall. I thought it did a better job than the other pad cleaner that I've used(CG pad cleaner)by a good margin! The pads rinsed out very clean and came out nice and fresh. The cleaner has a slight chemical odor, but it's not repulsive or overwhelming by any means. I was very satisfied with this product and highly recommend it!
Befores:
Afters:
Thoughts:
