Mike,
You and I occupy different places in this space. I appreciate your position as what I would call a fair representative of all the machines, as I said, showcasing each machine in the best possible way. That's important because people who read this board use all those different tools and your demonstrations make all their jobs easier. That's your job here and so, again, nice work.
Thank you, I try my best to be fair and balanced plus honest.
When I say the Makita FTW, it's just what works for me.
I believe the best tool is the tool you like and use and for each of us, this can and will be different.
The combination of the rotary and PO5000 lets me get work done faster than any other method. Speed on the big things matters to me because it leaves me more time for refining when that's called for. Speed isn't just speed for speed's sake, it's about getting more accomplished and more accomplished should mean higher quality and better value for money.
I completely agree. Most my friends that know my detailing style know I'm fast and furious, I like to get and get the job done then stick a fork in it and get it out the door.
I bet Jeff would still have the Makita if it spun the same direction as the rotary he's spent all those years using. All that muscle memory would have made the Makita disappear in his hands.
RSW
I agree.
For some people, the direction of pad rotation is the deal maker, not the deal breaker. For me? I don't really care which way the pad rotates, it's s non issue, but that's just me.
Mike would you say the new makita po5000c has more cutting power then the Flex XC 3401
No.
In my classes and in my writing I always say,
"The little things are the big things" -Mike Phillips
And while the difference between a 5mm orbit stroke length and an 8mm orbit stroke length may be a "little thing" now after using the Makita PO5000C, the RUPES Mille, (both of these tools are 5mm orbit stroke length) and the FLEX 3401, with it's 8mm orbit stroke length, to be the fastest for correction work with out inflicting holograms like a rotary buffer.
But that's just me...
I do believe a lot of people will prefer the Makita PO5000C and the RUPES Mille, (bot 5mm orbit stroke length), exactly because the smaller orbit stroke length results in a smoother buffing experience overall.
I don't care about a smoother buffing experience, I care about speed and effectiveness.
